Why flow appears on suction side of the blade in simulation?
Old   May 7, 2020, 13:15
Default Why flow appears on suction side of the blade in simulation?
MA
mazhar16823 is on a distinguished road
I am running the simulation for a wind turbine blade using implicit unsteady solver. As inflow direction is along z-axis, but in the reference coordinate system Z is pointing opposite to the inlet therefore I described the flow direction [0,0,-1] and kept the positive inlet velocity ''+x'' m/s.
However, for drag force and drag coefficient the direction is [0,0,1].
For the moment coefficient, direction is [0,0,-1]
For the rotation rate, in moving reference frame axis direction is: [0,0,1] and rotational speed is kept ''-x m/s'' considering clockwise rotation.
The simulation is converged, but the flow appears on suction side of the blade instead of pressure side, consequently flow is not attached along the blade. It can be seen from the plot of iso-contours of Q criterion (left) whereas the coordinate system is also shown on the right.
Can anyone please tell why is it happening?
mazhar16823 is offline   Reply With Quote
Old   May 10, 2020, 11:44
Smile
SimulatorMaster's Avatar
Onur
SimulatorMaster is on a distinguished road
Hello again =D
The problem is perhaps the direction you assigned at the inlet. As a default, the flow velocity will be normal to the surface (velocity inlet). Maybe the direction you assigned reverses the flow? Try to revert back the default setting.
SimulatorMaster is offline   Reply With Quote
Old   May 10, 2020, 11:50
MA
Originally Posted by SimulatorMaster View Post
Hello again =D
If you look at the picture on the right showing coordinate system Z-axis is pointing opposite to the inlet. However, my flow direction is along Z-axis, so according to the coordinate system I mentioned the flow direction [0,0,-1].
Whereas, the blade is aligned with Y-axis, thus rotates in X-Y plane.
blade, simulation, starccm+
Turbomachinery Mass imbalance sheaker CFX 12 September 5, 2019 08:09
[blockMesh] Flow domain by BLOCKMESH for plasma induced flow simulation mukut OpenFOAM Meshing & Mesh Conversion 0 June 2, 2014 06:19
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
[Commercial meshers] Converting meshes that includes interfaces ham OpenFOAM Meshing & Mesh Conversion 29 January 8, 2007 08:58
