basic fluid dynamics question: Flow though time
let we think we simulate air flow on an airfoil. The length of airfoil is 1 m. And the CFD-Domain has 30 m in the direction of the flow. Velocity is 30 m/s. then in this case, my flow though time is... 1. 1 s? or 2. 1/30 s? I think 1/30 s is right... |
I'd say that is completely up to you, if you want it to be a complete domain flow-through or an airfoil flow-through. For my work on channel flows we define a flow-through as the time it takes from the domain inlet to the domain outlet, but your problem is different.
Also, if such accuracy would be desired, remember that the flow-through time for the suction surface of the airfoil will be shorter than for the pressure surface, but I doubt that level of accuracy is what you're looking for! |
Flow thru time is 1 s. 1/30 seconds isn't the right answer, it's wishful thinking.
It's the same as channel flow, the initial condition needs to get washed out completely |
