May 20, 2020, 10:00 |
setting angle of attack nicely 0°
niewiemnic
Rep Power: 8 |
https://drive.google.com/file/d/1mdJ...ew?usp=sharing
hello, can anybody give me a small tipp to set an angle of attack nicely? I thought I set the angle with 0° (ventilator blade) correctly, but it seems not like that (see the link). I used freeCad. |
May 20, 2020, 12:54 |
Gerry Kan
Rep Power: 10 |
Hallo SA:
At first glance your blade does not seem to be at alpha = 0. If this is a NACA airfoil, draw a straight line from the leading to the trailing edge. The slope of this line is indicative of your angle of attack, that is, at alpha=0 it should be parallel with the horizontal datum line (x-axis). Otherwise the polynomial expression of the foil shape should be defined at alpha = 0 already. If you want your alpha = 0 defined at zero lift (or Cf = 0), you would need to run some tests (javafoil comes to mind; inviscid flow will do). The lift should vary linearly with alpha around zero lift so you only need two or three points to locate the angle. Hope that helps, Gerry. Last edited by Gerry Kan; May 21, 2020 at 06:33. |
Wind tunnel simulation; Varying the angle of attack | Dronzer | FLUENT | 5 | December 24, 2022 23:36 |
induced angle of attack in VLM | ZakBristol | Main CFD Forum | 0 | June 23, 2019 12:37 |
how to change angle of attack of a rotating blade in frozen rotor | momo_sjx | CFX | 0 | January 26, 2013 10:53 |
introducing angle of attack on ICEMCFD HEXA | icem beginner | CFX | 2 | December 24, 2008 11:00 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
