XROTOR Compilation and Operation
Old   May 20, 2020, 21:06
Default XROTOR Compilation and Operation
Moshe Hollander
mhollander is on a distinguished road
I'm not sure if CFD Online is the right place to ask this question, but I figured it would be a good place to start.
Part of my work involves analyzing propellers and I have been told that XROTOR would be a good tool for what I need to accomplish. I'm having some trouble compiling and running the program. Has anyone managed to successfully do so on either an Ubuntu or Windows 10 system? If so, how did you manage to successfully compile and run it? Following the documentation provided on the XROTOR site is getting me nowhere.
mhollander is offline   Reply With Quote
Old   August 18, 2020, 20:28
Default Installing XROTOR
Andhra Pradesh
sayin is on a distinguished road
Did you manage to install XROTOR.
sayin is offline   Reply With Quote
Old   August 18, 2020, 21:14
Moshe Hollander
I downloaded CROTOR which is basically XROTOR with some 'add-ons'. You can just use the XROTOR functionality if that's what you want to do.
http://www.esotec.org/sw/crotor.html
Old   September 21, 2023, 02:32
Haniyeh is on a distinguished road
I'm having troubles using Xrotor too. I'm using it to analyze a propeller, but unfortunately I can get the results which exist in an article. the first datum is right (thrust has the exact amount of experimental thrust) but after that CT doesn't change and always follows the same trend.
Haniyeh is offline   Reply With Quote
propellers, rotorcraft, xrotor
loading issue libraries:libsimpleFunctionObjects.so libsimpleSwakFunctionObjects.so immortality OpenFOAM Pre-Processing 15 April 7, 2024 12:35
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 06:47
complex number operation in udf? hongxiao FLUENT 5 June 14, 2017 14:11
reduce an equal operation T.D. OpenFOAM Programming & Development 1 September 6, 2016 12:00
Incompatible dimensions for operation ruben23 OpenFOAM Running, Solving & CFD 2 June 12, 2015 04:14
