Flow Past a Cylinder with Non-Zero Average Lift Coefficient
Like Tree1Likes
  • 1 Post By innoaloe
Old   May 21, 2020, 21:21
Default Flow Past a Cylinder with Non-Zero Average Lift Coefficient
Innocentio Loe
innoaloe is on a distinguished road
I've been working on simple flow past a cylinder simulation with Re=100.
Boundary condition is flat velocity profile on the inlet, 0 on the outlet, and slip top and bottom wall.
The domain is 20d in width and 10d in height, with the cylinder centered at the origin, 5d to both left and bottom wall
I'm trying to validate the result, compared to literature data.
Expected lift and drag coefficient (CL and CD) around the cylinder wall are CL = +/-0.33 and CD = 1.34 +/-0.009
The simulation is working fine. However, what I notice is that even though my CL oscillates at the correct amplitude, it is not oscillating around 0 average but instead has small negative average value instead.
Also my CD is oscillating around 1.42 instead, so I guess there is the same DC drift happening as well here.
For the CL, it is easy to remove this additional drift, but for CD I cannot really do so, since there is no baseline of judgement.
My question is whether this is commonly encountered? If so, how to validate such a case then? I'm using COMSOL Multiphysics at the moment. Might try to compare with OpenFOAM later on.
innoaloe is offline   Reply With Quote
Old   May 22, 2020, 03:07
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Have you checked that the grid is perfectly symmetric?
FMDenaro is offline   Reply With Quote
Old   May 22, 2020, 06:41
Innocentio Loe
Hi, thank you for your input. Certainly I haven't thought about the mesh symmetry. Also, currently I am using an unstructured mesh which maybe will make it harder to create symmetrical mesh. I will try using a structured mesh.
Old   May 24, 2020, 05:20
Gerry Kan's Avatar
Gerry Kan
Gerry Kan is on a distinguished road
Dear innoaloe:
One thing you should also check is whether the CL oscillates about some value as the solver iterates. It could be that the solution is oscillating, as it happens physically. Look at your solution field to verify.
Gerry
PS I am sorry I did not read your entire message. I would second with FMDenaro and use a perfectly symmetric mesh. I don't know if you can do this natively with COMSOL but I would be surprised if you couldn't. Otherwise you need a very fine mesh to attenuate any asymmetric effects.
Gerry Kan is offline   Reply With Quote
Old   May 24, 2020, 07:19
Innocentio Loe
Originally Posted by Gerry Kan View Post
Dear innoaloe:
Gerry
Dear Gerry,
thank you for your input as well. I did as FMDenaro's suggested to create symmetrical mesh, also ensuring the mesh around the cylinder to be more refined. And yes, it is possible to do so in COMSOL.
I managed to get an acceptable result by doing so. There is still a very tiny average value on the oscillation, but the value is negligible if compared with the CL oscillation itself, so in my opinion such small numerical error is to be expected.
Regards
Gerry Kan likes this.
comsol, drag coefficient, lift and drag, lift coefficient
Simulating Flow past Circular Cylinder parthiv1991 OpenFOAM Running, Solving & CFD 4 June 3, 2018 05:19
Drag force coefficient too high for a flow past a cylinder using komega sst Scabbard OpenFOAM Running, Solving & CFD 37 March 21, 2016 16:16
Drag Coefficient for flow past a Cylinder o_mars_2010 Main CFD Forum 0 April 18, 2013 06:17
How to calculate the drag coefficient for flow past cylinder o_mars_2010 Tecplot 0 April 18, 2013 01:26
Drag coefficient of flow past cylinder vs time pedroxramos FLUENT 0 January 14, 2013 12:39
