Moving fluid vs moving body
Like Tree2Likes
  • 1 Post By lovecraft22
  • 1 Post By sbaffini
Old   June 7, 2010, 15:59
Default Moving fluid vs moving body
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Hi everybody, I have a question for you:
every time I run a simulation the fluid is moving while the body is still. That means that the situation is similar to the one you would find in a wind tunnel with all it's disadvantages.
So I was thinking about moving the body while the rest of the domain is still. The ground should be a wall if the body is a car and the other domain faces could be simmetry plane or a pressure condition could be imposed on them.
Would it be a good idea? Is there something I'm missing? What do you think?
Thanx
Lorenzo
lovecraft22 is offline   Reply With Quote
Old   June 7, 2010, 17:04
kdrbrk's Avatar
Burak
kdrbrk is on a distinguished road
Lorenzo,
In order to eliminate boundary layer of the ground(wall which is under the car) while flow is moving, I give the ground "velocity inlet" boundary condition with "magnitude and direction" option. Also except symmetry plane and outflow, everywhere is velocity inlet.
By this way, I think I get a good approach like the real world.
Hope it makes sense to you.
kdrbrk is offline   Reply With Quote
Old   June 8, 2010, 03:58
lore
Yess, that's what I do as well. I was just wondering which would be the difference between setting a case like you described and setting one like I described.
Old   May 24, 2020, 14:01
Hector
hectorgabriel85 is on a distinguished road
Hi, I was wondering if somebody else has another explanation.
hectorgabriel85 is offline   Reply With Quote
Old   May 24, 2020, 17:47
lore
Moving the body carries the drawback that you need to rebuild the volume mesh in the wake of the vehicle and this comes at a price. You would also need to refine the mesh in front of the vehicle as it passes by.
hectorgabriel85 likes this.
Old   May 24, 2020, 18:29
Hector
I agree when we see it as a transient problem with moving boundaries: body moves with respect to control volume and remeshing is needed.
What if we see it as a stationary problem? A body fixed in space with respect to control volume as usual (so no remeshing is needed) with the unusual boundary condition: velocity prescribed on the boundary of the body as movingWallVelocity.
Old   May 25, 2020, 02:42
lore
No, that would not work as movingWall is only a surface condition that has an impact on the air that wets the surface. I believe the only case where that would work is a zero thickness flat plate moving parallel to the flow at 0° angle of attack.
Old   May 26, 2020, 17:28
Hector
I wish I had the time to check this in OpenFOAM: solve two laminar small problems with same mesh: first one with moving fluid and second one with moving body and compare pressure and viscous forces over body.
Old   May 26, 2020, 17:42
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
There are differences, because numerical schemes are not perfect
https://www.google.com/url?sa=t&sour...BhO1xuW13jHUkb
sbaffini is offline   Reply With Quote
application part of laminar newtonian fluid past bluff body swamysrikanth Main CFD Forum 0 December 15, 2009 01:53
applications of laminar newtonian fluid past a bluff body swamysrikanth FLUENT 0 December 15, 2009 01:51
how to accelerate fluid in bluff body case? Rui Main CFD Forum 7 March 5, 2009 10:45
Moving a rigid body in a fluid doum OpenFOAM Running, Solving & CFD 2 April 4, 2007 09:09
Heat transfer to fluid and pipe body Chris FLUENT 1 December 28, 2002 02:09
