formulation of convective term
Old   June 25, 2000, 21:39
Default formulation of convective term
Zeng
Problem: vertor a=(ar,aq,az) and vector b=(br,bq,bz) ar,aq,az represent the component in radial(r), circumferential(q) and axial(z) direction, respetively.
Delta is gradient operator in cylindrical coordinate
What is (a·Delta)b ?
I encounter it when I deal with a problem with linear stability analysis. I need a full form in r,q,z direction for coding.
Your help is highly appreciated.
Zeng
fax:[81]22-215-2052
Old   June 25, 2000, 22:20
Default Re: formulation of convective term
John C. Chien
(1). Take a look at the convection term first. You may be able to get the expanded form there. I mean the conservation equations.
Old   June 26, 2000, 00:47
Zeng
Yes, I have checked the expended form of convection term in N-S equation, and derived the expended term of (a·Delta)b by myself, but I have no confidence on its correction, and I failed to find the expended form in the reference books.
Maybe the expended form of (a·Delta)b in cylindrical coodinate exist in reference, can you kindly help me to find them?
Thanks in advance.
Old   June 26, 2000, 14:41
Sergei Chernyshenko
Hi, Zeng,
The formulae you are looking for can be found in
G.K.Batchelor, An introduction to fluid dynamics, Cambridge University Press, 1970, Apendix 2.
or
G.A.Korn, T.M.Korn, Mathematical handbook for scientists and engineers, McGraw-Hill, 1961. Table 6.4.1 + Table 6.5.1
Rgds, Sergei
RAS Turbulence Models - Convective Term john_w OpenFOAM 3 May 29, 2010 21:31
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
How to suppress the convective term SAKTI Siemens 1 August 28, 2008 01:38
Convective term evaluated at time n+1/2 Lionel S. Main CFD Forum 0 February 12, 2007 14:22
Approximation Schemes for convective term Michail CFD-Wiki 10 July 31, 2006 14:33
