May 27, 2020, 06:23 |
Convergence Issue
MA
Rep Power: 6 |
Hi everyone,
I have run a simulation based on 6 M cells mesh. The direction of rotation is such that flow is coming from leading edge to trailing edge of the blade i.e. [0,0,-1]. However, the axis set for the moment coefficient is [0,0,1]. After getting the monitor plot for moment coefficient, I see that it is not converged the first portion of the plot gives high values and other gives lower values. Could you please tell me what could be the reason for this? P.S: I am using STARCCM+. Thanks for your time. |
May 29, 2020, 14:52 |
Vignesh Rajendiran
Rep Power: 9 |
Please try to explain your problem in a clear manner. Your question is confusing. Go into specifics for others to identify the problem.
May 29, 2020, 15:25 |
#3 | |
MA
Rep Power: 6 |
I am simulating the flow around a wind turbine blade. My simulation settings are as follows: Time-step size: 0.001 s Number of time-steps: 500 Number of inner iterations: 5 If there is something else you want to know, let me know. |
convergence check, moment coefficient |
Display Modes | |
Issue with convergence criteria value | MMatt | FLUENT | 3 | February 11, 2020 08:05 |
Convergence issue with moving surface | pd.iiest | FLUENT | 0 | August 30, 2019 04:06 |
Convergence issue with continuity equation | Jake | FLUENT | 8 | June 6, 2018 04:41 |
convergence issue for transonic turbulent case | aeroiitkgp | SU2 | 5 | May 12, 2015 17:44 |
Convergence issue | Jake | FLUENT | 3 | June 30, 2005 05:12 |
