The pressure fluctuation contains the turbulence and acoustic compent? |
April 13, 2022, 08:54 |
Rinia
Rep Power: 8 |
Hey, CFDers
I am performing a simulation about the unmanned drone propeller with compresible LES. The instantaneous pressure fluctuation is obtain by subtracting the time-average pressure from the pressure. I would to know if the pressure fluctuation obtained in this way contains the turbulence and acoustic compent, and if it is possible to obtain acoustic pressure fluctuation only? Thank you in advance. |
April 13, 2022, 10:39 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
They are not exactly as same as in case of a DNS. |
April 13, 2022, 13:39 |
Lucky
Rep Power: 65 |
To clarify, yes they do contain the acoustic and the turbulence fluctuations. But... LES is spatially filtered. The filtered variables only contains the filtered parts of the fluctuations. There are fluctuations at the sub-filter scale which are not included in the filtered velocities which you need to also add if you want to account for fluctuations at all scales.
The acoustic component you can get by ensemble averaging the pressure results; more generally, you would apply a temporal filter. Turbulence is random so the ensemble average will eliminate them. It's also sometimes called a phase average. Note that there are as many ensemble averages as there are ensembles. Ensemble averaging is feasible if you know a priori which specific frequencies are of interest so you can average only those ensembles, otherwise you have an infinite number of them. |
Generate convective pressure fluctuation | Bananenflanke | CFX | 10 | May 12, 2021 18:33 |
Acoustic Power Discrepancy | Time4Tea | FLUENT | 0 | August 21, 2018 09:46 |
Acoustic Model of Slightly Underexpanded Supersonic Jet Not Working | ZNoel | FLUENT | 0 | March 9, 2018 18:09 |
Acoustic Analysis using Fluent and ANSYS mechanical | ankit1512 | ANSYS | 0 | November 10, 2013 18:46 |
Noise and Turbulence | Matthias | Main CFD Forum | 9 | May 11, 2001 04:38 |
