Turbulence: Inertial Subrange Question
Old   July 2, 2020, 07:01
Default Turbulence: Inertial Subrange Question
geth03 is on a distinguished road
hi all,
i'm performing an analysis with my simulation.
i want to determine the inertial subrange in my domain.
the lower boundary is calculated by:
l_DI = 60 * eta = 60 * (kinematicViscosity^3 / epsilon)^0.25
the upper boundary is calculated by:
l_EI = 1/6 * k^(3/2) / epsilon
source: http://www.bakker.org/dartmouth06/engs150/09-kolm.pdf
also same equations can be found in
Andersson et al., Computational Fluid Dynamics for Engineers
however, when i output the result my lower boundary is always higher than my upper boundary, which can't be correct, bc per definition it should be vice versa.
does anybody know whats wrong here?
king regards
geth03 is offline   Reply With Quote
Question Regarding Turbulence Numerics cfdengineer CFX 7 January 27, 2016 16:06
General question: turbulence and laminar models fluentmonkey Main CFD Forum 12 March 17, 2011 14:47
Question...Turbulence Intensity & Viscosity ratio Jay FLUENT 1 October 6, 2005 04:41
Inertial diffusive subrange Xu Zhou Main CFD Forum 0 June 8, 2000 15:42
Question about Low Re turbulence modelling. ghlee Main CFD Forum 1 May 28, 1999 19:29
