Reason for Swril and Backflow in Fan Simulation |
July 2, 2020, 17:04 |
kumar
Rep Power: 6 |
Hi everyone,
I am trying to Simulate fan in an enclosure of length 500 mm front & behind the fan. incompressible Unsteady simulations boundary conditions: Pressure Inlet and Pressure outlet - 0 gauge pressure (default) Cell zone conditions: Rotating fluid domain with 3000 Rpm as the Continuity is diverging I reduced relaxation factor momentum to 0.4 and KE to 0.4 run simulation for 150 iterations So in the pathlines of flow, I can see the swirl and backflow. as I am new to fan Simulation I have no idea whether they are common in the simulation. If they arent how to solve them in the simulation Thanks in advance |
July 4, 2020, 11:38 |
Rep Power: 14 |
try with extended 2x, 3x, 4x computational domain
November 14, 2020, 17:28 |
Kira
Rep Power: 8 |
Backflow is occurring because your domain is not long enough. Try modifying that parameter.
November 17, 2020, 07:40 |
Sascha
Rep Power: 13 |
swirl and backflow are common behind the fan. Indeed extending your outlet section will help to avoid problems related to backflow, as you are providing more computational domain for the flow to settle, but you can also switch from "Outlet" to "Opening" definition, which will allow backflow. |
Convergence and backflow problem in cavitation simulation | burakaltintas | CONVERGE | 2 | August 9, 2016 07:42 |
Constant Power Fan Model using General Momentum Source | Dano62 | CFX | 0 | April 14, 2016 13:09 |
Backflow at outlet in a Eulerian gas-solid simulation | audrey | CFX | 10 | October 25, 2012 06:15 |
Backflow in eulerian multiphase simulation | xeusater | FLUENT | 0 | June 26, 2009 07:50 |
backflow in a jet simulation | Hao | CFX | 0 | October 3, 2008 02:23 |
