Turbomachinery Convergence Issue
Hi All,
I have been working on Centrifugal Compressor project and I have an important questions about it. I hope the experts in this field will help me, thanks in advance. 1- When I just use TurboGrid default mesh about 200.000 it will quickly convergence and give some reasonable results but if I check y+ value its about 700 and it is not right for cfx or fluent suggested range , I tried for finer mesh and it shows that more good quality resolution around boundary layer its going to more unstable and diverge after few iteration. I can't decrease y+ value without increase mesh count. So how could I solve this problem ? Here is some things that I tried.. * I searched for it and a lot of people say that you should decrease physical time step but it did not work. * First I solve problem with coarse mesh then I use flow field variables as an initial condition for fine mesh but it did not work too. * I use some expert parameters and try to decrease under relaxation factors but it did not solve the problem either. So what should I do for get y+ about 70-100 range ? Here is case conditions that I use ; Inlet : Stationary Frame Total Pressure Outlet : Mass Flow Outlet ( Design Conditions) Others are classic TurboMode boundaries (Periodicity,wall..etc) Material : Air Ideal Gas Turbulance Model : k-epsilon (I did not want to solve boundary completely so ı just use this) |
