heat of combustion
Old   July 11, 2020, 01:29
Default heat of combustion
mohsen
841911 is on a distinguished road
i have e reaction for Propane and heat of combustion is 24.2 MJ/kg.
I don't know how to set 24.2 MJ/k in CFX?
Can you hlp me?
Tnx
841911 is offline   Reply With Quote
Old   December 24, 2020, 23:48
Kira
aero_head is on a distinguished road
Hello Mohsen,
Please check out this thread, I believe it goes over what you are asking:
change heat of combustion
In sum, ANSYS CFX does not use the heat of combustion, or heat of fuel explicitly anywhere in the combustion model. It uses thermodynamic properties of the material. The ANSYS CFX implementation of the energy equation does not use any split of the enthalpy material definition.
For these properties (and you can consult a Thermodynamics book),
Sample reaction: A * Propane + B * O2 + C * N2 --> D * CO2 + E * H2O + F * N2
heat of combustion formula as a function of the enthalpies defined as:
h_material = h_material_ref + Cp_material (T - T_ref)
Once you work out the heat of combustion, it should be a function of the reference enthalpy of your type Propane and the adiabatic flame temperature for the value you have.
aero_head is offline   Reply With Quote
Old   December 25, 2020, 12:01
Gerry Kan's Avatar
Gerry Kan
Gerry Kan is on a distinguished road
Dear Mohsen:
The 24.2 figure you posted is some kind of heating value (as an aside for hydrocarbons it should be closer to 50 MJ/kg fuel, you should check it again).
That said, you don't specify heat of reaction in a reaction. What you need are the (temperature dependent) heats of formation for each of the species involved in your reaction mechanism, as part of their thermophysical properties. The energy released will be summed up across all species according to your mechanism and local thermodynamic state.
Hope that helps, Gerry.
Gerry Kan is offline   Reply With Quote
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
Heat Release vs. Apparent Heat Release // Comparison with GT Power MFGT CONVERGE 10 August 17, 2016 02:38
Which type of heat transfer's model AVL-Fire use in internal combustion engines? amin_u50 AVL FIRE 0 May 13, 2014 12:02
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Combustion with heat transfer and cooling KamilSobczak FLUENT 0 June 16, 2010 09:28
