wrong results in simulation
Like Tree1Likes
  • 1 Post By bluebase
Old   August 8, 2020, 18:39
Default wrong results in simulation
wahba
amwahba4 is on a distinguished road
where the problem could be in such a case in simulation of vertical wind turbine
as the results are upnormal
amwahba4 is offline   Reply With Quote
Old   August 10, 2020, 18:45
Sebastian Engel
bluebase will become famous soon enough
Hi wahba,
abnormal is not a specific enough term to give concrete advice - other than asking you to put more thought in your question and post.
If you need advice, try to describe your problem in detail, what you have tried to solve it yourself, what you might not understand. This will increase your chance of receiving a voluntary advice.
Might these suggestion be helpful for you?
Best,
Sebastian
amwahba4 likes this.
bluebase is offline   Reply With Quote
Old   August 10, 2020, 20:31
wahba
thanks sebastian for your interest,
i'm doing a simulation for on vertical wind turbine i got undesirable results such power coff is much higher normal ones in papers.
i noticed the velocity contour on low speeds such 40 rpm is logical but in high speed which i need to calculate at has the abnormal results as the high velocity occurs at the tip of rotating zone not the turbine tip as expected (the inserted pic)
i am using transiet flow with moving mesh and also the steady flow with MRF had the same high result.
How to restart simulation using results from other solver sahmed OpenFOAM Running, Solving & CFD 8 July 5, 2019 07:02
Validation of 2D simulation and experimental results mizzou OpenFOAM Running, Solving & CFD 8 April 4, 2017 10:31
udf error srihari FLUENT 1 October 31, 2016 15:18
Radiator simulation wrong results dennis722 STAR-CCM+ 7 September 22, 2016 21:40
Results of an axisymmetric simulation in Fluent ShimiSan FLUENT 0 July 19, 2016 10:20
