help in multi Layer 1d transient conduction
Old   August 10, 2020, 04:46
Default help in multi Layer 1d transient conduction
AGAAMAZ is on a distinguished road
hello everyone
iam solving 3-Layers 1d transient conduction problem by fortran
i want your help at this point :
i calculate time step from this relation
Time step =(Fo*density*Cp*(dx^2))/K
and since each material has a different K so i have 3 calculated time steps
which gives me 3 time loops
how can i solve this in the right way
thanks in advance
AGAAMAZ is offline   Reply With Quote
Old   August 10, 2020, 08:48
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Take the smaller time step as simplest working solution. After all, it is just 1d, it's not going to cost you that much.
If you want to overkill, you can advance them at different time steps, but requires much more coding to keep everything consistent
sbaffini is offline   Reply With Quote
[snappyHexMesh] No generation of layer onto zerothickness surface crubio.abujas OpenFOAM Meshing & Mesh Conversion 3 October 25, 2022 04:20
Transient heat conduction computation time reduction Mowgli OpenFOAM 0 October 8, 2019 10:48
asking transient conduction to get heat transfer extraction teguhtf FLUENT 0 February 19, 2019 00:24
how to simulate the conduction without meshing the wall layer buidu Main CFD Forum 3 May 18, 2015 17:26
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 14:47
