[Sponsors] | |||||
ANGELO
Rep Power: 7 ![]() |
I am working on a project using Static acoustic of Ansys. I have A disk with a shaft(solid domain-Steel) and a cylindrical fluid domain(Air or water). I defined my acoustic region as the cylindrical fluid and my structural region as the disk with the shaft and then I try to apply a force on the disk surface, and it doesn't work saying that ''This structural load should be defined on structural region'' although the disk is defined as structural region. I tried to apply loads on the same disk before and it worked very well. You can see the photo attached. I appreciate your help Thanks, Angelo |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| p_rgh initial residual no change with different settings | manuc | OpenFOAM Running, Solving & CFD | 3 | June 26, 2018 16:53 |
| Recursive output of Foam::word in gdb print command | chengdi | OpenFOAM Programming & Development | 1 | July 19, 2017 21:19 |
| Big difference in simulation&analytical result of a simple static structural problem | cli21 | ANSYS | 1 | May 28, 2017 14:59 |
| FSI Fluent -> static structural | zytra | ANSYS | 4 | October 16, 2014 18:01 |
| Transfer from CFX to Static Structural | student82 | CFX | 1 | March 2, 2011 05:17 |
