UDF for parallel use in combination with scheme possible?
Hi I have the follwoing code that comuptes the variable fnew. Depending on the value ><0 I set the variable veldirect to 0 or 1. Everything works fine in serial, but not in parallel.
In parallel the printed value for veldirect is always 0. I use this variable in a scheme code that is executed every timestep. I am not sure if this will affect the parallel usage. I tried several types of this code now but I am not really sure around which line I should use host or node execution. In other codes it was more intuitive to me. [CODE] **** calculated fnew here **** DEFINE_ADJUST(adjust_UDS_bc, d) { #if !RP_NODE /*execute on host or in serial */ if (fnew >= 0) { RP_Set_Integer("veldirect", 0); } else { RP_Set_Integer("veldirect", 1); } #endif } [CODE] node_to_host_int_1(count); this is something that migth be needed as well? But again I couldnt really understand where in my case to use. |
