Error while running the modified channel case |
September 11, 2020, 08:24 |
Arijit Saha
Rep Power: 7 |
Hi, everyone I am using Time Varying Mapped Field for the inlet at different time-step but I m encountering error after running for few time-step. For eg when I m keeping the deltaT at 0.1 it is stopping at 3.5 sec, when 0.01 at 11 sec, when 0.02 at 15 sec...
Note:- I m using the channel flow case where I modified the blockMeshDict for my utility. The error looks like this as follows:-\ Code:
#0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::tmp<Foam::GeometricField<Foam::outerProduct<double, double>::type, Foam::fvPatchField, Foam::volMesh> > Foam::sqr<double, Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:? #4 Foam::LESModels::WALE<Foam::IncompressibleTurbulenceModel<Foam::transportModel> >::k(Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> const&) const at ??:? #5 Foam::LESModels::WALE<Foam::IncompressibleTurbulenceModel<Foam::transportModel> >::correctNut() at ??:? #6 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/pimpleFoam" #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/pimpleFoam" Floating point exception (core dumped) |
LES of channel flow: data, case files, technical report. | tiam | OpenFOAM Running, Solving & CFD | 34 | June 12, 2023 08:11 |
Case files (constant) being deleted while running. | Kieran | OpenFOAM | 0 | February 21, 2019 13:16 |
Running AMI case in parallel | Kaskade | OpenFOAM Running, Solving & CFD | 3 | March 14, 2016 15:58 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
How to save a case running in background | us | FLUENT | 0 | July 6, 2005 10:43 |
