Problem with NuT
Hi, I am trying to simulate a turbulent PIMPLE flow. I am using OpenFoam6.
I am getting this error: --> FOAM FATAL IO ERROR: Essential entry 'value' missing file: /home/jan/0/nut.boundaryField.barkley from line 52 to line 54 nut is defined like this: Quote:
Does anyone have any idea? Thanks, Jan |
I can't see it there but usually this error is due to a missing colon, a line that is commented out accidentally etc. Is it possible you're missing a parameter or two in barkley?
Essential entry 'value' missing file: /home/jan/0/nut.boundaryField.barkley from line 52 to line 54 The above message shows that value entry is missing in the following: barkley { type nutkRoughWallFunction; Ks uniform 0.000755; Cs uniform 0.5; value uniform 0; } Hope this helps, Fumiya |
Hi Fumiya,
Thanks I will try running it with the value entrance. I understood the error, what I don't understand is that the documentation doesn't say that value needs to be specified for this OF version. Only Ks and Cs Code:
Hi MaySea,
The value entry is necessary because the nutkRoughWallFunctionFvPatchScalarField class is inherited from the fixedValueFvPatchScalarField class. I understand that the value is only a place holder for nutkRoughWallFunction and does not have any effect to simulation results. Hope this helps, Fumiya |
