Why zero pressure boundary condition?
Like Tree3Likes
  • 2 Post By LuckyTran
  • 1 Post By FMDenaro
Old   October 12, 2020, 09:25
Default Why zero pressure boundary condition?
SuperSonicCat is on a distinguished road
i am currently studying CFD. In many examples for a simulation of internal flows the zero pressure bc at the outlet is set. I am wondering why? In my understanding that means vacuum at the outlet.
When can i set the pressure bc to zero and when i should set the gradient of the pressure to zero?
Lets say i want to simulate a flow through a pipe- segment. I only know the inlet velocity. Which pressure outlet bc should i use if the pressure at the outlet is unknown?
I really want to understand that
Best regards.
SuperSonicCat is offline   Reply With Quote
Old   October 12, 2020, 09:37
Lucky
Most CFD software works in gauge pressures. The zero pressure at the outlet is a gauge pressure and not the absolute pressure.
Which outlet BC to use depends on a lot of details which you have aptly omitted about your model: what equation of state you are using, whether your flow is compressible or not, details of the solver, etc. For incompressible flows, the pressure BC doesn't really matter and you just need to apply the BC to make your software happy. For compressible flows, you can't joke around.
cfd.rishabh and SuperSonicCat like this.
Old   October 12, 2020, 09:58
Hello LuckyTran,
thank you very much for your answer!
So if i want to simulate an incompressible, turbulent flow, zero pressure at the outlet is always a good choice?
Best regrads.
Old   October 12, 2020, 16:59
Hello everyone,
i think i understand it now.
In case of a simulation of a steady incompressible internal flow i can always choose the following boundary conditions:
fixed inlet velocity and zero outlet pressure.
Why:
- in most cases i know the inlet velocity (trivial)
- the pressure in NS- equations is given in form of a gradient, so
it is necessary to specify a fixed pressure value at one point
in order to get one special solution of the equations
- If i set the pressure at outlet to zero, the pressure at the inlet
will be calculated by the solver to satisfy the NS- equations
- I can now calculate the pressure loss and i can analyse the
streamlines
- relative Pressure loss and streamlines are independent of the
chosen pressure outlet value.
Please tell me if something is wrong.
Best regards
Old   October 14, 2020, 13:33
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by SuperSonicCat View Post
Hello everyone,
Why:
streamlines
Best regards
No, there is no such a necessary condition to get a solution for the pressure equation. Theoretically, one solution exists provides the compatibility equation is fulfilled. Such solution is determined implicitly by the solver (apart a constant).
SuperSonicCat likes this.
FMDenaro is offline   Reply With Quote
pressure boundaries
Appropriate pressure boundary condition in incompressible flow lonelywing OpenFOAM Running, Solving & CFD 21 June 6, 2022 09:44
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Total Pressure boundary condition in the OpenFOAM dli OpenFOAM Programming & Development 1 December 5, 2017 23:16
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
