Home > Forums > Software User Forums > COMSOL
COMSOL parametric scanning
Old   December 11, 2020, 05:12
Default COMSOL parametric scanning
lbj007 is on a distinguished road
I find that when I calculate something that geometric parameters should be changed using parametric scanning, it will show some error after calculating several parameters, not all of them.However, when I try to calculate the case it shows error before, not using scanning, it just works fine.What's more, it can calculate to the end of the parameter's list when the parameter is not about geometry So I guess something goes wrong inside comsol.
Does anyone know its reason? Or maybe it is solved in version 5.6,I'm using 5.5
lbj007 is offline   Reply With Quote
comsol 5.5, parametric scanning
Parametric study by Ansys Workbench Sahar FaPerhu ANSYS 17 August 23, 2017 03:29
Gmsh: Preparing mesh for use in COMSOL StudentIB Mesh Generation & Pre-Processing 0 June 21, 2017 16:00
Comsol (4.3): convert parametric surface into block? sgalaz COMSOL 0 November 9, 2012 09:20
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
pressure distribution in water flow, differences in icoFoam and COMSOL deniggo OpenFOAM Running, Solving & CFD 14 September 30, 2010 03:48
