November 2, 2020, 05:27 |
Stl to solid Body?
Hi i have already export a wind turbine blade as an stl file but i cannot import it on ansys as an solid body. Could someone help me with it?
Thank you in advance. |
November 10, 2020, 09:40 |
Carlo_P
Rep Power: 7 |
If you use SpaceClaim, you have to go on Faceting and then you can solidify it.
https://www.youtube.com/watch?v=OC_wY_ml4vk |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 06:01 |
Limiting the maximum rotation angle of a solid body in a fluid | invadoria | OpenFOAM Running, Solving & CFD | 0 | May 20, 2017 11:03 |
[DesignModeler] Merge surface body and solid body | balmyheart | ANSYS Meshing & Geometry | 0 | December 19, 2016 04:39 |
[DesignModeler] Merge Surface Body and Solid Body | prikeyma | ANSYS Meshing & Geometry | 5 | April 16, 2015 07:01 |
[DesignModeler] how to subtract a surface body from a solid body? | yahya | ANSYS Meshing & Geometry | 4 | January 7, 2013 11:00 |
