Convergence problems unsteady conjugate heat flow problem when refining mesh
Old   December 2, 2020, 04:32
Default Convergence problems unsteady conjugate heat flow problem when refining mesh
Sven_netherlands is on a distinguished road
I'am trying to solve an incompressible unsteady conjugate heat flow problem for an uniformly heated cylinder in a laminar flow of water using Comsol. The cylinder is located at the centerline and the inlet boundary is located at 8D and outlet boundary at 25D. The height of the domain is equal to 24D.
All differential equations are dimensionless and are dependent on the Reynolds, Prandtl and Richardson numbers. In this case these numbers are equal to 20, 7 and 1 respectively.
Note that the equations are nondimensionlized by setting \rho and \mu equal to 1 and \frac{1}{Re} respectively for the laminar flow module. Furthermore, bouyancy is added by using the boussinesq approximation and is included in the y term of the volume force as Ri \Theta for which, \Theta = (T - T_0)/(T_w - T_0) is the dimensionless temperature.
For the heat transfer module Cp is set to 1 and k to \frac{1}{Pr Re}
The boundary conditions are:
Inlet
Uniform inlet velocity of 1
And inflow temperature of T_0 = 0
Upper and lower boundary
Slip boundary conditions and heat conduction normal to the wall set to 0
Cylinder
No slip condition
Temperature of the wall T_w = 1
Outlet conditions
Zero pressure outlet condition
Conduction normal to the wall set to 0
Mesh
The mesh is mapped with quads elements and are non uniformly distributed. The statistics are shown below:
Number of elements 133200
Minimum skewness 0.4995, average 0.9889
Minimum volume versus circumradius 0.2049, average 0.774
Minimum condition number 0.2692, average 0.7876
Minimum growth rate 0.9628, average 0.9849
Boundary minimum element size 0.0134
Solver
I'am using a seggregated solver
Convergence
Up to around 100000 elements the convergence is good but for finer meshes the error of the segregated solvers shows a fluctuating error after a time of around 40 seconds. The residuals also increase significantly in this period of time. These plots can be found in the attachment. Furthermore, after the error appears ''May have reached a singularity.
Time: 40.593993119146752 s.Last time step is not converged.'' A plot containing undefined values of the variable comp1.T appears and is also included in the attachment. Just before the simulation quits the timestep also decreases significantly. The reciprocal of the time step plot is included in the attachment.
Can anybody help me with this problem. The effort is greatly appreciated.
Best regards,
Sven Beekers
Master student University of Technology Eindhoven
Sven_netherlands is offline   Reply With Quote
convergence, flow, heat, mesh
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 04:37
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
Mesh suggestions for a conjugate heat transfer problem maddalena Main CFD Forum 1 January 25, 2013 17:39
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 10:55
