Can we group multiple structured blocks together to speedup calculations?
2 Attachment(s)
In the pictures shown below, I have multiple structured blocks at different layers.
Normally experts who developed BoxLib, AMRex, apparently just solve the different blocks in different CPUs using MPI. That makes sense since their computations are extremely large, and there's no way all of the data could be stored onto a single machine. For my case, I don't care about scaling to thousands of cores. My objective is to make it run as fast as possible on a single core. For that objective, it's bad to solve these blocks separately. If I try to solve them on multiple structured blocks, I will have to enforce the bounday conditions betweeneach block, every iteration. That would be bad. Also, I don't want to use MPI, I want to use OpenMP. I'm greedy about performance. I want it all.:rolleyes: I'm thinking about flattening out the whole level (multiple structured blocks) into a single 1D array, and iterating over the whole thing using i=1,ncells_in_level. In this method, I will only have to worry about setting the boundary conditions once (only between the grid levels L, L-1) per iteration and the whole freakin' calculation will be vectorized.:) Will that work? What should I look out for, so that i don't blow off my own foot doing this? Because if this works : Lord forgive me for the performance boost I'm about to receive!!:p EDIT : Upon further investigation, it looks like I will still have to update the data between the different boundary blocks, but the vectorization potential is still a good outcome. Aaaaannnnddd, since everything's in the form of 1D arrays, I can absolutely distribute the work onto 4 of my CPU cores using OpenMP!!!!!! Thanks ~sayan |
Is this an implicit or explicit code?
Yes Andy, that seems like a great way to do it!:) |
Hey andy, I thought about this. Can we keep the ghost/halo cells in a separate array? I have the solution update loop as : Code:
#pragma omp simd linear(i:1) Since I will allocate the arrays as U_ = [U_ for block 1][U_ for block 2] ... [U_ for block N], i.e in a single contiguous memory block, I can't have the ghost/halo cells inside this region. Is it okay if I keep them in a separatearray? Or will it cause too much problem down the line? This is the first time I'm using halo cells, so I don't know much about them. Thanks:) BTW : Are you Andrew Hollingsworth? |
It is easy enough to check but the ghost cells approach is likely to be computationally faster with simpler coding at the cost of a bit more storage. I am not Andrew Hollingsworth whoever he may be. |
1 Attachment(s)
Thanks for your help Andy. I agree that the indirect referencing will be a little more complicated, and there may be performance penalty, I will have to see if I can make that efficient. The flux calculations will be slow by default, there are so many branches inside it. Including this indirect referencing will also include a lot of branches if I implement it naively. A naive implementation would be : Code:
if(at_boundary) My plan was to use a single 1D array that will contain all of the ghost cell data, in exactly the order they will be accessed in. This is shown in the attached image. In this case, even if the structured block is large, the data will be present in at least L2 cache. Writing into it will be fast, and reading from it will also be fast. |
This tends to mean writing the simplest realistic scheme first (e.g. halo cells in this case) and testing it on small problems and large realistic problems. If it looks as if a more elaborate scheme might be worthwhile (i.e. achieved performance is less than 50% or so of theoretical) then develop a more elaborate scheme to address the deficiencies that have been measured. Typically when raising the computational performance of an existing numerical code only a few routines tend to matter and although most are the ones one would have picked beforehand quantitative measurement via profiling can change the assumed relative importance. |
