[Sponsors] | |||||
moh
Rep Power: 13 ![]() |
hi gues
During modeling of water evaporation below boiling point (between 30 to 40°c) i use FLUENT UDF to model diffusion where the saturated pressure is calculated using this expression real T = C_T(cell, liq); P_SAT = exp(77.345 + 0.0057*T - 7235 / T) / pow(T, 8.2); then i use the saturated pressure to calculte the vapor partial pressure via this expression real p_vap =P_SAT *(MWair/(MWair+MWvapor*(1/mf_vapor-1))) ; MWair molecal weight of air MWair molecal weight of vapor mf_vapor vapor mass fraction = C_YI(cell, vap,0) fluent macro IS THIS correct ???? and how i can get relative humidity if i now mass fraction and molecal weight ?? |
moh
any suggestions please
Kira
Rep Power: 11 ![]() |
To your first question, there are some threads on here about that, like so: how to obtain mass diffusion coefficient with UDF? Your second question is a really basic thermodynamics problem. You can read up on the relevant topics online, here's an example: https://www.learnthermo.com/examples...on=D&problem=9 |
#4 | |
moh
TANK YOU FOR YOUR HELP MY problem is with vapor pressure and where the displayed value is not expected at all My UDF FOR MASS TRANSFERT is based on CARRIES EQUATION : any help will be very appreciated DEFINE_LINEARIZED_MASS_TRANSFER(cav_source, cell, thread, from_index, from_species_index, to_index, to_species_index, d_mdot_d_vof_from, d_mdot_d_vof_to) { Thread *liq = THREAD_SUB_THREAD(thread, from_index); Thread *vap = THREAD_SUB_THREAD(thread, to_index); real T = C_T(cell, liq),P_SAT = exp(77.345 + 0.0057*T - 7235 / T) / pow(T, 8.2); real m_dot=0.0, dp, m_source=0.0, p_op = RP_Get_Real("operating-pressure"); real rho_v = C_R(cell, vap),rho_l = C_R(cell, liq); real vof_l = C_VOF(cell, liq); real vof_v = 1.0 - vof_l; real r_rho_lv = 1. / rho_v - 1. / rho_l, h_fg = 2437426.07; /*%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%*/ real p_vap = (C_P(cell, thread) + p_op); //real p_vap = (C_P(cell, thread) + p_op)*(28.96/(28.96+18.01*(1/mf_vapor-1))) ; //real p_vap =P_SAT *(28.96/(28.96+18.01*(1/mf_vapor-1))) ; real vel = sqrt(C_U(cell, thread)*C_U(cell, thread) + C_V(cell, thread)*C_V(cell, thread)); if (p_vap <= P_SAT) { dp = P_SAT - p_vap; dp = MAX(dp, 1e-4); m_dot = (0.0888 + 0.0783*vel)* dp / h_fg; m_source = m_dot*vof_l; C_UDMI(cell, thread, 1) = m_source; C_UDMI(cell, thread, 2) = P_SAT; C_UDMI(cell, thread, 3) = p_vap; C_UDMI(cell, thread, 5) = vof_v; C_UDMI(cell, thread, 7) = vof_l; *d_mdot_d_vof_from = m_dot; *d_mdot_d_vof_to = -m_dot; } else { dp = P_SAT - p_vap; dp = MAX(dp, 1e-4); m_dot = 0.0; m_source = m_dot*vof_l; C_UDMI(cell, thread, 2) = P_SAT; C_UDMI(cell, thread, 3) = p_vap; C_UDMI(cell, thread, 5) = vof_v; C_UDMI(cell, thread, 7) = vof_l; C_UDMI(cell, thread, 1) = m_source; *d_mdot_d_vof_from = m_dot; *d_mdot_d_vof_to = -m_dot; } if (NNULLP(THREAD_STORAGE(thread, SV_MT_DS_DP))) C_STORAGE_R(cell, thread, SV_MT_DS_DP) = ABS(r_rho_lv*m_source / dp); return m_source; } any help will be very appreciated |
moh
PLEASE i need helps from mass transfert expert
masoud fard
Rep Power: 5 ![]() |
Dear Tahar
I hope you I doing well, I know this post is so old, but I would like to know if you got the results using this UDF/ |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| What is difference between static pressure and gauge pressure? | aja1345 | FLUENT | 2 | May 28, 2025 03:07 |
| Simple Box - Gravity with Pressure Outlet - Unrealistic Reverse Flow | pyccknn | FLUENT | 2 | December 1, 2021 18:31 |
| Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 06:35 |
| Discharge of Pressure Vessel into Pipe with Regulator | gajowni2 | System Analysis | 0 | October 31, 2015 19:57 |
| Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
