June 24, 2000, 21:58 |
Turbulent fluctuating components
In some papers I found that they randomly sample fluctuating components of velocities from the Gaussian distribution based on the r.m.s value of turbulent intensities. But how exactly they do it?
July 7, 2000, 06:26 |
Re: Turbulent fluctuating components
i could not understand what u've tried to convey.can u be more clear and specific.
senthil k |
July 7, 2000, 08:42 |
Okay, from numerical simulation we get only mean components of velocities. If we want to approximate the fluctuating velocities, we need to do it based on the auto correlation (i.e., turbulence intensities) of the turbulent flow. As a matter of fact these square root of turbulence intensities are the RMS values of the fluctuating components. So some authors sample these fluctuating velocities from a Gaussian distribution with mean = zero and standard deviation = square root of turbulence intensities. I came to knew about the sampling method later after posting the message. I was wondering why so far nobody answered to this message. However if I'm wrong or you have anything more to say please do continue.
Turbulent Boundary Layer on a Flat Plate | Hoshang Garda | FLUENT | 1 | November 27, 2013 10:24 |
Using different turbulent viscosities for turbulent stress components | braennstroem | OpenFOAM Running, Solving & CFD | 13 | October 15, 2010 08:59 |
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel | nuimlabib | Main CFD Forum | 0 | August 4, 2009 00:05 |
getting fluctuating velocity components at FLUENT. | Seyfettin | FLUENT | 0 | November 25, 2005 02:50 |
to know fluctuating components | R.THUNDIL KARUPPA RAJ | FLUENT | 1 | June 29, 2005 17:30 |
