Is it possible to enable shared topology in Fluent meshing as opposed to spaceClaim?
I made a slightly complicated multi-part geometry in Solidworks, and then imported it as an IGES into Fluent. The problem is, I am using ANSYS student version, so I cannot open it in SpaceClaim, switch to shared topology, then close it. This is because Student version has a limit on the number of faces and bodies, and will not save the geometry if I exceed that limit. I must necessarily import the file into Fluent meshing as is, without adjustments in SpaceClaim. Is there a way to set it to shared topology in the mesher itself? Alternatively, can I adjust the geometry file settings to make it load as shared topology file? https://19216881.org/ https://1921681001.link/ https://19216801.digital/
192.168.100.1 – 192.168.l00.1 Admin Login
Problem with 192.168.100.1 address
Everytime I type in the 192.168.100.1 address, I receive a message "Internet Explorer Cannot Display Webpage". I have tried this several times and it doesn't connect me to the website. HELP! 192.168.100.1 – 192.168.l00.1 is a private IP address commonly used at home and offices to manage and change router admin settings. It is mostly used by brands Motorola, Ubee, Arris, Lenovo, Netronix, Planet, ZyXEL, etc. |
