May 12, 2021, 23:59 |
Grid-scale
Rep Power: 4 |
Can someone please help me to understand what is Grid-scale in the context of the following sentences taken from Boris et al. 1992:
1. It is only in the last several years, however, that a connection has been drawn between the grid-scale behavior of these algorithms and the need for and required properties of a subgrid-stress model to represent the unresolved “turbulent” scales. 2. ...highlighting the close interaction between the grid-scale errors in the underlying CFD algorithm and the subgrid turbulence model. |
May 13, 2021, 04:40 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
If I understand the reference, the context of these sentences is about the MILES formulation proposed by Boris. That is about the role of local truncation error as well as that of the FCT scheme is acting as an implicit SGS model at the grid size level. |
May 13, 2021, 08:35 |
Rep Power: 4 |
Hello FMDenaro,
Thank you for the answer. Yes, these are indeed in the context of MILES. If I correctly understood your answer, in this paper Grid-scale is nothing but the size of the grid, say h along the x direction. Is my understanding correct? |
May 13, 2021, 08:39 |
Rep Power: 71 |
Yes, that sentence should imply the “computational” grid-size
grid-scale (les) |
Mesh Conversion : structured to unstructured | shreyasr | ANSYS | 8 | April 8, 2019 07:03 |
Control function in Poisson eqtion grid generation? | dinhanh | Main CFD Forum | 0 | January 8, 2017 01:53 |
[ICEM] Regarding O Grid | anand32 | ANSYS Meshing & Geometry | 0 | December 30, 2016 09:57 |
How to find a good time scale strategy? | StefanG | CFX | 19 | June 8, 2012 08:41 |
TUI command for grid scale in mm | Ralf Schmidt | Fluent UDF and Scheme Programming | 2 | March 16, 2009 06:06 |
