Explication about lift.
Old   July 15, 2000, 17:43
Default Explication about lift.
Marcos Eike
Hi all,
What é lift? and what do it do?
Ats, Marcos EIke
Old   July 15, 2000, 19:26
Default Re: Explication about lift.
John C. Chien
(1). Lift is to increase the potential energy. (2). If moving upward will increase the potential energy, then, aircraft, elevator, and escalator are devices to increase the potential energy (and these are lifting devices.) (3). Since there is a common sense principle: "what goes up must also come down.", make sure that you take the same device to go the round trip. (4). Free fall sometimes is faster to get back to the origin, it is not the ideal way back. So, as long as you have the LIFT, make sure that it is with you all the time until you are safely back. (5). By the way, a faster way to increase the potential energy is to ride the rocket. That's why they always say: 10,9,8,7,6,5,4,3,2,1,0, ignition, we have lift-off.
Lift distribution PB4 STAR-CCM+ 6 May 31, 2016 09:46
Lift coefficient in Eulerian multiphase model hennas FLUENT 1 July 4, 2011 16:50
Vortex Lattice Method: Calculating lift using circulation from vortex ring elements black&gold Main CFD Forum 11 June 26, 2011 23:51
Thin foil analsis (sail) - Lift Coeff Problem Kelvin CFX 3 December 22, 2008 16:22
Saffman Lift Force CFD MAN Main CFD Forum 0 November 26, 2002 18:26
