combustion third order time accuracy using runge kutta method
Hello everyone,
This is the follow up post of my earlier thread as i didn't find error after long check out. However i realized that there is no combustion(no reaction and no heat release )in the simulation so i am getting lower temperature. Combustion was working fine before upgrading time accuracy using rk4 method. i checked chemistry properties and combustion both are on and true. Also i am using "rhoCombustionModel" . can anyone suggest possible solution or error on the fomulation of species and energy equation specially involving reaction. Thank you. I was facing the problem with time accuracy of the solution using first order Euler ddt. So, i thought of implementing rk4 third order time accuracy. Following represents the equations: rho = rhoOld + rkCoef[cycle] *runTime.deltaT()*(-fvc::div(Riemann.rhoFlux())) momentum equations. rhoU = rhoUOld + rkCoeff[cycle]*runTime.deltaT()*(-fvc::div(Riemann.rhoUFlux())+fvc::div(tauMC)+fvc:: laplacian(muEff, U)); species transport eqn: fvScalarMatrix YiEqn ( rhoYi - rhoYOldi - rkCoeff[cycle]*runTime.deltaT()*(-fvc::div(Riemann.rhoScalarFlux(i))+ fvm::laplacian(turbulence->muEff(), Yi)) == rkCoeff[cycle]*runTime.deltaT()*reaction->R(Yi) ); energy eqn rhoE = rhoEOld + rkCoeff[cycle]*runTime.deltaT()*( --fvc::div(Riemann.rhoEFlux() + fvc::div(sigmaDotU) + fvc::laplacian(turbulence->alphaEff(), h) +fvc::laplacian(k,T)+reaction->Sh()); OF2.3.1 courant number and timesteps are calculated as per rhocentralFoam. Thank you all. |
