Shock tube test case
I am trying to simulate Sod's shock tube using PISO and FVM in MATLAB. I tried making this code but the results are wrong. Can someone check the code and let me know where the error is
Thank you. % Code for Inviscid flow in a shock tube close all clear all clc n_points =101; % These are the velocity nodes P nodes would be n_points+1 dom_length = 0.35; dx = dom_length/(n_points-1); x = 0:dx:dom_length; %These are the velocity nodesor cell faces x_Press(1:n_points-1) = x(1:n_points-1)+(dx/2); % initialize the variables dt = 2.05*10.^-6; % dt = 1; time = 0; final_time = 1; highP = 6.897*10.^4; lowP = 6.897*10.^3; highTemp = 288.89; lowTemp = 231.11; % high_Density=1 % low_Density = 0.125 Gas_Constant = 287.049; gamma = 1.4; guess_Vel(1:n_points) = 0; for index = 1:n_points-1 if x_Press(index) < 1.524*10.^-1 g_Pressure(index) = highP; else g_Pressure(index) = lowP; end end Ini_P = g_Pressure; % mean = mean(g_Pressure) % Specify the initial conditions for index = 1:n_points-1 if x_Press(index) < 1.524*10.^-1 g_Pressure(index) = g_Pressure(index); Temperature(index)= highTemp; g_Density(index) = (g_Pressure(index))./(Gas_Constant*Temperature(index)); Sound_Speed(index)= sqrt(gamma*Gas_Constant*Temperature(index)); else g_Pressure(index) = g_Pressure(index); Temperature(index)= lowTemp; g_Density(index) = (g_Pressure(index))./(Gas_Constant*Temperature(index)); Sound_Speed(index)= sqrt(gamma*Gas_Constant*Temperature(index)); end end Ini_P = g_Pressure; while time < final_time %Dirichlet BC on the 1st and last velocity bound node while the %momentum equation will be solved for 2nd to 2nd last velocity CV % Find density on velocity nodes for the transient term for index = 1:n_points if index ==1 Den_on_Vnodes(index)= highP/(Gas_Constant*highTemp); elseif index == n_points Den_on_Vnodes(index)= lowP/(Gas_Constant*lowTemp); else Den_on_Vnodes(index) = (g_Density(index-1)+g_Density(index))/2; end end % Find velocity on scalar nodes for the non linear term for index = 1:n_points-1 V_On_Scalars(index) = (guess_Vel(index) + guess_Vel(index+1))/2; Den_Vel(index)= g_Density(index)*V_On_Scalars(index); end % Find gradient of pressure on velocity nodes for index = 1:n_points if index == 1 gradP(index) = 0; elseif index ==n_points gradP(index) = 0; else gradP(index) = (g_Pressure(index-1) - g_Pressure(index)); end end % Combine RHS of the x mom eq for index = 1:n_points RHS(index)= gradP(index) + (Den_on_Vnodes(index)*guess_Vel(index)*(dx/dt)); end % complete the equations V_Pred= sym('V',[1 n_points]); for index = 2: n_points-1 if index ==2 eqn(index) = ((Den_on_Vnodes(index)*(dx/dt))+Den_Vel(index))*V_Pred(index) == RHS(index); else eqn(index) = -(Den_Vel(index-1)*V_Pred(index-1))+(((Den_on_Vnodes(index)*(dx/dt))+Den_Vel(index))*V_Pred(index)) == RHS(index); end end [A,B] = equationsToMatrix(eqn(2:n_points-1),V_Pred(2:n_points-1)); Pred_Velo(2:n_points-1) = linsolve(A,B); Pred_Velo(1) = 0; Pred_Velo(n_points) = 0; Pred_Velo = Pred_Velo'; % 1st pressure correction % find new density and corr density for index = 1:n_points-1 DenS(index) = g_Pressure(index)/(Gas_Constant*Temperature(index)); CorrDen(index) = ((DenS(index) - g_Density(index))*dx)/dt; end for index = 1:n_points-1 P_Source(index) = -CorrDen(index)+ (Den_on_Vnodes(index)*Pred_Velo(index)) - (Den_on_Vnodes(index+1)*Pred_Velo(index+1)); end % complete the equations P_Corr= sym('P',[1 n_points-1]); for index = 1: n_points-1 if index == 1 P_eqn(index) = 2*P_Corr(index) - P_Corr(index+1) == highP+ 2*g_Pressure(index) - g_Pressure(index+1)- highP + P_Source(index)*(dx/dt); elseif index == n_points-1 P_eqn(index) = 2*P_Corr(index) - P_Corr(index-1) == P_Source(index)*(dx/dt)+2*g_Pressure(index)- g_Pressure(index-1)-lowP+ lowP; else P_eqn(index) = 2*P_Corr(index) - P_Corr(index-1) - P_Corr(index+1)== P_Source(index)*(dx/dt)+ (2*g_Pressure(index))- g_Pressure(index-1)-g_Pressure(index+1); end end [C,D] = equationsToMatrix(P_eqn,P_Corr); % [C, D] = equationsToMatrix([P_eqn(1),P_eqn(2), P_eqn(3),P_eqn(4), P_eqn(5), P_eqn(6), P_eqn(7), P_eqn(8),P_eqn(9), P_eqn(10), P_eqn(11), P_eqn(12), P_eqn(13),P_eqn(14), P_eqn(15), P_eqn(16), P_eqn(17), P_eqn(18),P_eqn(19), P_eqn(20), P_eqn(21), P_eqn(22), P_eqn(23),P_eqn(24), P_eqn(25), P_eqn(26), P_eqn(27), P_eqn(28),P_eqn(29), P_eqn(30), P_eqn(31), P_eqn(32), P_eqn(33),P_eqn(34), P_eqn(35), P_eqn(36), P_eqn(37), P_eqn(38),P_eqn(39), P_eqn(40), P_eqn(41), P_eqn(42), P_eqn(43),P_eqn(44), P_eqn(45), P_eqn(46), P_eqn(47), P_eqn(48),P_eqn(49), P_eqn(50), P_eqn(51), P_eqn(52), P_eqn(53),P_eqn(54), P_eqn(55), P_eqn(56), P_eqn(57), P_eqn(58),P_eqn(59), P_eqn(60), P_eqn(61), P_eqn(62), P_eqn(63),P_eqn(64), P_eqn(65), P_eqn(66), P_eqn(67), P_eqn(68),P_eqn(69), P_eqn(70), P_eqn(71), P_eqn(72), P_eqn(73),P_eqn(74), P_eqn(75), P_eqn(76), P_eqn(77), P_eqn(78),P_eqn(79), P_eqn(80), P_eqn(81), P_eqn(82), P_eqn(83),P_eqn(84), P_eqn(85), P_eqn(86), P_eqn(87), P_eqn(88),P_eqn(89), P_eqn(90),P_eqn(91), P_eqn(92), P_eqn(93),P_eqn(94), P_eqn(95), P_eqn(96), P_eqn(97), P_eqn(98),P_eqn(99),P_eqn(99), P_eqn(100)], [ P_Corr(1), P_Corr(2), P_Corr(3), P_Corr(4), P_Corr(5), P_Corr(6), P_Corr(7), P_Corr(8), P_Corr(9), P_Corr(10), P_Corr(11), P_Corr(12), P_Corr(13), P_Corr(14), P_Corr(15), P_Corr(16), P_Corr(17), P_Corr(18), P_Corr(19), P_Corr(20), P_Corr(21), P_Corr(22), P_Corr(23), P_Corr(24), P_Corr(25), P_Corr(26), P_Corr(27), P_Corr(28), P_Corr(29), P_Corr(30), P_Corr(31), P_Corr(32), P_Corr(33), P_Corr(34), P_Corr(35), P_Corr(36), P_Corr(37), P_Corr(38), P_Corr(39), P_Corr(40), P_Corr(41), P_Corr(42), P_Corr(43), P_Corr(44), P_Corr(45), P_Corr(46), P_Corr(47), P_Corr(48), P_Corr(49), P_Corr(50), P_Corr(51), P_Corr(52), P_Corr(53), P_Corr(54), P_Corr(55), P_Corr(56), P_Corr(57), P_Corr(58), P_Corr(59), P_Corr(60), P_Corr(61), P_Corr(62), P_Corr(63), P_Corr(64), P_Corr(65), P_Corr(66), P_Corr(67), P_Corr(68), P_Corr(69), P_Corr(70), P_Corr(71), P_Corr(72), P_Corr(73), P_Corr(74), P_Corr(75), P_Corr(76), P_Corr(77), P_Corr(78), P_Corr(79), P_Corr(80), P_Corr(81), P_Corr(82), P_Corr(83), P_Corr(84), P_Corr(85), P_Corr(86), P_Corr(87), P_Corr(88), P_Corr(89), P_Corr(90), P_Corr(91), P_Corr(92), P_Corr(93), P_Corr(94), P_Corr(95), P_Corr(96), P_Corr(97), P_Corr(98), P_Corr(99), P_Corr(100)]); P_1st_corr = linsolve(C,D); % P_1st_corr(1) = 0; % P_1st_corr(n_points-1) = 0; % P_1st_Corr_new = g_Pressure + P_1st_corr'; % Corrected velocity for index = 1: n_points if index == 1 Corr_Vel(index) = 0; elseif index == n_points Corr_Vel(index) = 0; else % Corr_Vel(index) = Pred_Velo(index) + ((dt/(Den_on_Vnodes(index)*dx))*(P_1st_corr(index-1) - P_1st_corr(index))); Corr_Vel(index) = ((dt/(Den_on_Vnodes(index)*dx))*(P_1st_corr(index-1) - P_1st_corr(index))); end end % Corr_Vel_new = Corr_Vel + Pred_Velo; % Mass flow for index = 1:n_points-1 RHS_Mass(index) = ((DenS(index) -g_Density(index))*dx)/dt; LHS_Mass(index) = (Den_on_Vnodes(index+1)*Corr_Vel(index+1)) - (Den_on_Vnodes(index)*Corr_Vel(index)); end for index = 1:n_points if index ==1 MachNumber(index) = 0; elseif index ==n_points MachNumber(index) = 0; else MachNumber(index) = Corr_Vel(index)./Sound_Speed(index); end end guess_Vel = Corr_Vel; g_Pressure = P_1st_corr; g_Density= DenS; time = time +1; disp(time) end figure(2) plot(x,Pred_Velo,'b','LineWidth',2) hold on plot(x,Corr_Vel,'r','LineWidth',2) xlabel('x (m)') ylabel('Velocity (m/s)') legend('predicted velocity', 'Corrected velocity') title ('Velocity') saveas(gcf,'Velcity.png') % as matlab figure file to reopen in case saveas(gcf,'Velocity.fig') % as matlab figure file to reopen in case figure(4) plot(x_Press, P_1st_corr ,'b','LineWidth',2) hold on plot(x_Press,Ini_P ,'r','LineWidth',2) legend('Corrected P','Initial P') xlabel('x (m)') ylabel('Pressure (Pa)') title ('Pressure') saveas(gcf,'Pressure.png') % as matlab figure file to reopen in case saveas(gcf,'Pressure.fig') % as matlab figure file to reopen in case |
