Unique vertices of triangulated surface!
Old   July 12, 2000, 03:47
Default Unique vertices of triangulated surface!
Anders Jönson
Does anyone know if one can state the maximum number of unique (not sure of the spelling ) vertices for a triangulated surface? That is, if I have 300 surface triangles, what is the maximum number of vertices?
Any good sites for such questions and other mesh topology related information out there?
Regards Anders
Old   July 12, 2000, 04:17
Default Re: Unique vertices of triangulated surface!
Robert Schneiders
Anders,
the number of vertices is roughly half the number of faces. This can be concluded from Euler's theorem:
number of faces + number of vertices = number of edges + 1
(for simply connected bodies without holes). For the surface mesh, the following equation holds:
3 * number of faces = 2 * number of edges
It follows:
number of nodes = 0.5 * number of faces + 1
Best regards,
Robert
Robert Schneiders MAGMA Giessereitechnologie GmbH D-52072 Aachen Kackertstr. 11 Germany Tel.: +49-241-88901-13 email: R.Schneiders@magmasoft.de www: http://www-users.informatik.rwth-aachen.de/~roberts/
Old   July 12, 2000, 16:39
Xiaoming
Dear Robert,
I think you must have committed a small error: Euler 's fomula is:
number of faces + number of vertices = number of edges + 2 (instead of 1)
So the final answer is:
number of nodes = 0.5 * number of faces + 2
Best, Xiaoming
Old   July 13, 2000, 02:26
Anders Jönson
Hi Robert,
Thanx for the fast answer. However, I am a bit confused about the last formulas. They does not seem to match a simple testcase. I agree on the first one number of faces + number of vertices = number of edges + 1 However, if you take a square and draw a line diagonally, then you will end up with 2 triangular faces, 4 vertices and 5 edges. Thus Eulers formula:
2 + 4 = 5 + 1 OK
However, the last formula does not add up.
While writing this I also read Xiaoming answer, and it seemed that his Euler variant must be wrong!
Any ideas?
Regards Anders
Old   July 13, 2000, 04:18
Robert Schneiders
the Xiaoming comment is right.
The test case you give is not a valid solid, and it does not fulfil the correct equation
2 + 4 = 5 + 2
If you a one quadrilateral face, you have a valid solid model (at least from a topological point of view), and the formula gives
3 + 4 = 5 + 2
Best regards,
Robert
Old   July 16, 2000, 11:04
PRAVEEN C
The simplest solid is a triangular based pyramid.
Faces(F) = 4 Vertices(V) = 4 Edges(E) = 6
So the correct formula is F + V = E + 2
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
