August 25, 2021, 16:16 |
Coupled scheme
Liam
Rep Power: 5 |
Hello there!
Can someone please explain to me how Coupled scheme works and when I can use it? I tried to search for information on the internet but I didn't found anything interesting or understandable. Any links would be helpful. |
August 26, 2021, 02:32 |
Lucky
Rep Power: 65 |
If you are asking about the Coupled Pressure-Velocity coupling scheme in Fluent...
It solves the continuity and momentum equations simultaneously for pressure and velocity instead of resorting to a pressure correction approach like in SIMPLE and such. It's almost always appropriate to use the coupled scheme. There are some differences in speed, convergence rate, and scalability in parallel performance. You might end up with a preference with experience but it's robust. |
cuopled, methods, schame |
how to understand high resolution scheme and high order scheme | iilw1314 | Main CFD Forum | 7 | April 12, 2022 12:29 |
Steady State Transonic & Supersonic Solver and P-V Coupled Scheme | waseeqsiddiqui | OpenFOAM | 0 | May 22, 2020 12:07 |
SIMPLE and COUPLED Scheme for Dual Rushton Stirred vessel flow field simulation | a.hazarika | FLUENT | 1 | February 11, 2020 04:01 |
Some confusion about coupled solver for incompressible flow | bearcat | Main CFD Forum | 0 | February 14, 2010 20:40 |
Definition of limiter function for central dirrerencing scheme | sebastian_vogl | OpenFOAM Running, Solving & CFD | 0 | January 5, 2009 11:08 |
