Accessing data generated by flexi (DGSEM solver) |
August 27, 2021, 06:46 |
Jnana Bhaskar Rao
Rep Power: 6 |
Dear all,
I have recently started working on the Discontinuous Galerkin Spectral Element Method opensource solver flexi. I am able to run the tutorials and even some advanced cases using it. However, I cannot access the solution values as they are saved in hdf5 format in binary files. I can visualize them when the state file sizes are smaller than 2GB in paraview. This requires converting the hdf5 files to vtu format using the "posti_visu" converter shipped with the code. However, as we go to higher order and finer meshes, the files become much larger in size and paraview crashes in trying to open them. I compiled the paraview reader that was shipped with the code so that I could directly open the hdf5 files with paraview. But on loading the reader and trying to open a state file with it I get a negative class id error and paraview crashes again. What I would like is a way to access property values in the hdf5 solution files itself as that would allow me to select the necessary data from the 3D domain and postprocess it as needed. However, as the data is written in binary format it doesn't allow access to hdfview software. Is there a way to extract the relevant data from the hdf5 state files? Meanwhile, any help with opening large vtu files or solving the negative class id error associated with the paraview reader is also most welcome. A sample state file of the cavity tutorial is attached for reference. JBR |
August 28, 2021, 05:49 |
Dear jnanabrao,
please share some more information otherwise no one can help you.
August 28, 2021, 06:11 |
Jnana Bhaskar Rao
Rep Power: 6 |
Hi Eifoehn4,
OS : Ubuntu 20.04LTS Paraview versions: I have 5.6.0 built from source code and 5.9.1 precompiled. The paraview reader was compiled with 5.6.0, although I had to obtain some vtk files separately that weren't present in the VTK library that came with 5.6.0 HDF5: please see attachment Open MPI: 4.0.3 Code:
Do you use precompiled release versions, the system versions or self compiled versions? flexi:Release version JBR |
August 28, 2021, 06:52 |
If you want to use the Paraview reader you have to make sure that FLEXI and Paraview are built with the same HDF5 Libraries. Moreover, HDF5 has to be built with FORTRAN and Parallel support. I would recommend to precompile HDF5 and OpenMPI on your own and use them for FLEXI and Paraview.
OpenMPI: Code:
./configure --enable-static --enable-mpi1-compatibility --prefix=/opt/openmpi/... Code:
cmake -DBUILD_TESTING=OFF -DHDF5_BUILD_FORTRAN=ON -DHDF5_BUILD_CPP_LIB=OFF -DHDF5_BUILD_EXAMPLES=OFF -DHDF5_ENABLE_PARALLEL=ON -DHDF5_BUILD_HL_LIB=ON -DHDF5_BUILD_TOOLS=ON -DHDF5_ENABLE_F2003=ON -DBUILD_SHARED_LIBS=OFF -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=/opt/hdf5/…
After that compile Paraview 5.6.0 with: Code:
cmake .. -DCMAKE_BUILD_TYPE=Release -DPARAVIEW_USE_MPI=ON -DPARAVIEW_INSTALL_DEVELOPMENT_FILES=ON -DPARAVIEW_USE_PYTHON=ON -DPARAVIEW_ENABLE_PYTHON=ON -DVTK_USE_SYSTEM_HDF5=ON -DHDF5_IS_PARALLEL=ON -DHDF5_PARALLEL=ON -DVTK_MODULE_vtkhdf5_IS_SHARED=OFF -DCMAKE_INSTALL_PREFIX=/opt/paraview/… Code:
See FLEXI docu ... Regards
Check out my side project: A multiphysics discontinuous Galerkin framework: Youtube, Gitlab. Last edited by Eifoehn4; August 28, 2021 at 08:32. |
August 30, 2021, 12:52 |
Jnana Bhaskar Rao
Rep Power: 6 |
After a few hiccups, it is working! Thanks a lot!
One tiny note:- To build paraview, I couldn't do without the mpi-cxx libraries and hence had to build those for openmpi with --enable-mpi-cxx option along with the rest of the configurations same as pointed out for openmpi above. JBR |
September 7, 2021, 13:11 |
Sure Python, Julia and MATLAB are able to handle HDF5 files. The more tricky part is the data visualisation, especially for complex topologies with holes.
In both cases you have to assign the coordinates to your data. Regards
Check out my side project: A multiphysics discontinuous Galerkin framework: Youtube, Gitlab. Last edited by Eifoehn4; September 7, 2021 at 14:14. |
September 8, 2021, 00:03 |
Jnana Bhaskar Rao
Rep Power: 6 |
Started working with h5py. Thanks as always! I really appreciate all the help.
dgsem, flexi, hdf5 binary files, paraview reader, vtu |
Divergence detected in AMG solver. VOF. | Mr.Mister | Fluent Multiphase | 4 | September 25, 2023 07:10 |
mathematical functions not working with Foam data type in ODE solver | Arham | Main CFD Forum | 3 | May 26, 2021 10:25 |
Validation Data for Riemann vacuum solver | Flexflix | Main CFD Forum | 2 | August 3, 2018 10:33 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
