How to calculate the eigenvalues of the Jacobian matrix of the chemical source term
Old   October 26, 2021, 09:18
Default How to calculate the eigenvalues of the Jacobian matrix of the chemical source term
ocean-yang
ocean-yang is on a distinguished road
Hi everyone:
As a cfd beginner I have a question about the Jacobian matrix of the chemical source term.
There is a method called Chemical Explosive Model Analysis(CEMA), which judges the local combustion mode by analyzing the eigenvalues of the Jacobian matrix of the chemical source term.(reference: T. F. Lu , C.S. Yo o , J. H . Chen , C.K. Law , J. Fluid Mech. 652 (2010) 45–64 . )
Unfortunately, I only use the Fluent software, and I don’t know how to extract the chemical source term of the grid and calculate the eigenvalues of the Jacobian matrix, do I need the udf function? Or do I need to use other software?
Looking forward to the guidance of people who understand the CEMA or those who understand the calculation of Jacobian matrix in the chemical source term, and welcome everyone to provide your ideas to exchange
ocean-yang is offline   Reply With Quote
Old   October 26, 2021, 13:25
Guruprasad S
guru112358 is on a distinguished road
If you are looking for quick and dirty ways to calculate Eigenvalues there are a variety of numerical methods:
for example Von Mises iterations gives the largest eigenvalue of a matrix with great simplicity
you need to hook up a UDF containing one of these routines written in C to Fluent,when the solver is running,you can make the UDF output the eigenvalues to your fluent terminal.
I have not personally worked on this sort of problem but I believe you need to use certain header files and syntax for this.
search for the fluent UDF manual,it pops up in a google search
as for extracting variables you can put something like a sensor point in Fluent
All the best!
guru112358 is offline   Reply With Quote
Old   October 27, 2021, 02:39
ocean-yang
Thank you very much for your reply, I believe it will be of great help to me.
chemical source term, eigenvalues, jacobian matrix
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 16:05
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 08:06
Source term for EVAPORATION in Energy Equ. - technical difficulty ? Kummi OpenFOAM 1 September 9, 2019 09:32
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
