open the analysis solved with ansys in star ccm+ |
October 28, 2021, 07:50 |
donkişot
Rep Power: 4 |
Hello my friends,
How can i view the post-process part of the analysis at ansys in star ccm? |
October 28, 2021, 13:39 |
Lucky
Rep Power: 65 |
Ansys is an entire company. Which part of Ansys are you referring to? Mechanical? Fluent? CFX?
If Fluent/CFX, you can import the volume meshes and otherwise the geometry directly into Starccm using File=>Import=>Import Volume Mesh. You cannot easily import the results. The better way to import results is to export them in the other software and transfer them over through a container like a .csv |
October 28, 2021, 19:26 |
Wise Locks
October 29, 2021, 04:19 |
#4 | |
donkişot
Rep Power: 4 |
October 29, 2021, 13:20 |
Lucky
Rep Power: 65 |
Export the solution data as a csv in Fluent. Import the csv table into Star in tools=> tables.
Watch a youtube video if you're a visual learner and you don't understand what any of that means. Afterwards, depending on what you plan on doing with the data, you might want to create a data mapper. Seeing as how you are already lost, I do not recommend even pondering what this means until after you've loaded the table into Star but I wrote it anyway to save you time later. |
October 30, 2021, 04:02 |
donkişot
Rep Power: 4 |
ı will try. thank you for your answer.
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 16:05 |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 35 | April 29, 2022 15:35 |
Pro/E to ANSYS Parameterization Guide | Trues | ANSYS | 4 | April 18, 2018 05:52 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
