what is the significant of stagnation pressure loss in fuel mixing after cavity |
November 13, 2021, 21:21 |
Ahmed Kamal Alnemr
Rep Power: 5 |
Hello,..
I am reading a scientific paper about the configuration of supersonic combustion. the system is consisted of cavity and grooves before the cavity. in the results of this study, the stagnation pressure loss occurred downstream the grooves. therefore I want to know what is its physical meaning of this ? |
November 13, 2021, 21:53 |
Lucky
Rep Power: 65 |
Stagnation pressure is the sum of static pressure and dynamic pressure. It is a measure of total available momentum in a moving fluid. Fluids can exchange static and dynamic pressure reversibly. Stagnation pressure loss therefore means an irrecoverable pressure loss occurred. The location of where this decrease in stagnation pressure occurs tells you where are the irreversibilities in your flow.
November 15, 2021, 06:35 |
#3 | |
Ahmed Kamal Alnemr
Rep Power: 5 |
November 16, 2021, 01:52 |
As indicated by LuckyTran, Stagnation pressure is the total quantity of energy in your fluid in terms of static and dynamic pressure.
In reversible process, static pressure is converted to dynamic pressure or vice versa according to Bernoulli principle. So total pressure remains same. Total pressure loss occurs due to various reasons. One can be due to friction effects on surface of some solid body. It can also occur in sudden mixing. |
November 16, 2021, 03:29 |
#5 | |
Ahmed Kamal Alnemr
Rep Power: 5 |
combustion modeling, reactive flow, supersonic.combustion |
Pressure drop across a converging nozzle | mjkey | CFX | 16 | July 17, 2019 13:22 |
CFX Solver stopped with error when requested for backup during solver running | Mfaizan | CFX | 40 | May 13, 2016 06:50 |
static vs. total pressure | auf dem feld | FLUENT | 17 | February 26, 2016 13:04 |
Pressure loss Velocity coupling | CFXMUFFIN | CFX | 1 | February 6, 2016 04:43 |
Outlet pressure | aja1345 | FLUENT | 5 | August 18, 2015 11:02 |
