November 17, 2021, 14:43 |
nutkRoughWallFunction ERROR
Elena Espana
Rep Power: 4 |
Hi Foamers!
I'm working on a simulation using pisoFoam, I'm using the nutkRoughWallFunction with the following parameters: The roughness height ks is required as the input of most nut wall equations, to assure a rough wall log layer between the center of the first near-bed grid cell and the wall. In our case, the first near-bed grid cell is equal to 5-cm, ks is 10-cm, and zo is approximately 2*ks (20-cm). FoamFile { version 2.0; format ascii; class volScalarField; object nut; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { bed { type nutURoughWallFunction; Ks uniform 0.1; Cs uniform 2; Cmu 0.09; kappa 0.41; E 9.8; roughnessFactor 1; value $internalField; } topWall { type slip; } sideRight { type slip; } sideLeft { type slip; } inlet { type fixedValue; value uniform 1e-06; } out { type zeroGradient; } } AND I GOT THIS ERROR: Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type LES Selecting LES turbulence model SpalartAllmarasDDES Selecting LES delta type smooth Selecting LES delta type cubeRootVol Selecting patchDistMethod meshWave LES { model SpalartAllmarasDDES; turbulence on; printCoeffs on; delta smooth; dynamicKEqnCoeffs { filter simple; } cubeRootVolCoeffs { deltaCoeff 1; } PrandtlCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } Cdelta 0.158; } vanDriestCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } Aplus 26; Cdelta 0.158; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } Ce 1.048; sigmaNut 0.66666; kappa 0.41; Cb1 0.1355; Cb2 0.622; Cw2 0.3; Cw3 2; Cv1 7.1; Cs 0.3; CDES 0.65; ck 0.07; } No MRF models present No finite volume options present #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 logf32x in "/lib/x86_64-linux-gnu/libm.so.6" #4 Foam::nutURoughWallFunctionFvPatchScalarField::yPl us(Foam::Field<double> const&) const at ??:? #5 Foam::nutURoughWallFunctionFvPatchScalarField::nut () const at ??:? #6 Foam::nutWallFunctionFvPatchScalarField::updateCoe ffs() at ??:? #7 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::evaluate() in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/pisoFoam" #8 Foam::LESModels::SpalartAllmarasDES<Foam::Incompre ssibleMomentumTransportModel<Foam::transportModel> >::correctNut() at ??:? #9 ? in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/pisoFoam" #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #11 ? in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/pisoFoam" Floating point exception (core dumped) Can anyone help me to understand and solve the error, please? Thanks
University of Texas |
Display Modes | |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 01:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 10:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
