Fluid Strain Singularities Similar to FEA Singularities
Like Tree2Likes
  • 1 Post By FMDenaro
  • 1 Post By sbaffini
Old   January 13, 2022, 18:06
Default Fluid Strain Singularities Similar to FEA Singularities
Chris
cbooks77 is on a distinguished road
Hi all I was curious if anyone has ever experienced fluid strain rates around sharp edges for example an impeller blade that are exceedingly high. I am running a fairly high mesh resolution (y+<1) case on a hydrofoil impeller and the volume averaged shear rates (fluid strain rate) inside the MRF region is around 20/s but the max strain rates being reported are around 100,000/s. Upon inspection these exceedingly high strains are occurring on the blade edges which were not filleted in the pre processor (see attached screenshot).
Now, since the strain rate is composed of velocity gradients I am wondering if the high resolution mesh around the sharp edge is causing the strain rate to blow up much like a stress singularity in FEA. For example, consider du/dx now as dx approaches zero it stands to reason that du would blow up.
Can anyone corroborate this theory so I can feel better about my results it will be nice to hear from you especially since I have never come across this topic in any CFD blogs or articles.
Kind Regards
cbooks77 is offline   Reply With Quote
Old   January 14, 2022, 05:06
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Kind Regards
if you think the simple case of a 2D corner, you understand the issue as due to the fact that the derivative cannot be defined, the corner is indeed a singular point. You have different limits.
cbooks77 likes this.
FMDenaro is offline   Reply With Quote
Old   January 14, 2022, 06:22
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Yet, there might also be post-processing issues in your picture, as you are apparently visualizing on the nodes, which is not the actual fv solution
sbaffini is offline   Reply With Quote
Old   January 14, 2022, 13:36
Chris
Hi that's correct I showed the interpolated data since its a boundary face and Fluent uses a simple averaging of the adjacent cell face values I believe. Also the cell values show similar behavior around the sharp edges. Thanks for your response
Intuition for why flow follows convex surfaces lopp Main CFD Forum 47 February 1, 2022 14:14
Condensation of water vapor to water visitor CFX 7 June 7, 2019 19:25
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
[ANSYS Meshing] Solid inside Fluid - Multizone meshing supercolli ANSYS Meshing & Geometry 2 July 9, 2014 14:20
Intl Conf Computational Methods in Fluid Power Jacek Stecki Main CFD Forum 0 November 10, 2002 06:49
