Simulation of Continuous Wire Galvanizing Process
Like Tree1Likes
  • 1 Post By Moreza7
Old   January 30, 2022, 03:41
Question Simulation of Continuous Wire Galvanizing Process
Moreza7 is on a distinguished road
Hi there,
I want to simulate a Continuous Wire Galvanizing process. As you can see in the figure, the wire with a diameter of "d" enters the molten "zinc" bath with a constant speed of "U". After leaving the zinc bath, the coating is applied. Please note that there is no air-jet wiping.
In the first step, I want to find the thickness of the liquid coating at any desired height after leaving the bath, and then, if possible, I wanna find the height at which the coating solidifies (according to the convection coefficient, the ambient temperature, and gravity).
Which software (for example Fluent, Flow-3D, COMSOL,...) and physics do you suggest for this simulation?
Thanks a lot
neelcfd likes this.
Moreza7 is offline   Reply With Quote
cfd, coating, comsol, fluent, simulation
Issues With Exporting From GMSH rberdon Mesh Generation & Pre-Processing 0 February 11, 2021 12:11
[OpenFOAM] could not open file .vtk in paraview ali_atrian ParaView 8 August 27, 2014 11:31
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 05:43
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
