April 24, 2022, 21:37 |
Ansys icepack
Wang Li
Rep Power: 4 |
Hi does any one know how to modify this fan(graphic card fan) in Ansys ICEPACK instead of fan with casing. I have attached pictures exactly what I want in Ansys Icepack.
April 24, 2022, 21:50 |
Kira
Rep Power: 8 |
Have you tried setting both of these values to zero?
April 24, 2022, 21:59 |
Wang Li
Rep Power: 4 |
its 3D fan ,can not be zero …..I think if I will use Fluid block and use 2D fans on all sides then will be possible …this the way which I can choose, what do you think
April 25, 2022, 01:11 |
Kira
Rep Power: 8 |
Hi Li,
I think that would work. If you put walls and one face for the fan inlet and one face for the fan outlet it should replicate it. |
April 25, 2022, 02:57 |
Wang Li
Rep Power: 4 |
ok thanks I will try
dc fan, heat sink, icepack, thermodynamic |
Running Ansys in BAtch Mode | kuleuvenstudent | ANSYS | 1 | October 18, 2017 12:11 |
[ANSYS Meshing] ANSYS mesh - I was surprised... | assafwei | ANSYS Meshing & Geometry | 0 | September 4, 2014 12:17 |
Ansys HPC licensing policy | assafwei | ANSYS | 0 | June 29, 2014 16:00 |
Using ICEM CFD to repair/edit ANSYS Meshing | Kaaji1359 | ANSYS | 2 | July 30, 2013 10:28 |
Exporting results from CFX to ANSYS ?? | sohail ahmed | CFX | 1 | December 20, 2007 01:10 |
