Y plus in buffer layer in StarCCM+
Like Tree4Likes
  • 1 Post By sbaffini
  • 1 Post By LuckyTran
  • 1 Post By Paulh
Old   May 11, 2022, 00:04
Default Y plus in buffer layer in StarCCM+
Hamed
hamed1983 is on a distinguished road
Hi all,
I have simulated a ship in a virtual wind tunnel, and I want to show Y+ in the buffer layer. As can be seen in the attached I have drawn Y plus for the surface of my model, even though I was wondering how do I have to indicate it for the buffer layer specifically? any help would be appreciated.
Regards
hamed1983 is offline   Reply With Quote
Old   May 11, 2022, 05:26
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
That's not how yplus contours work in any code, nor y+ in general. The contour you see is just a nondimensional version of your tau_wall (actually, its absolute value).
This nondimensional value is based on the y+ definition using the wall distance in the cell adjacent to the point of the surface where you see the contour.
So, for a given grid and solution, there is a single y+ value to show, the one related to your near wall cell and its tau_wall. That value might or not end up in the buffer layer, but this mostly depends from your grid.
Now, if you want to have a nice plot of the u+ vs y+ for a given profile extracted along a normal to the wall in a given point, you need to extract the tau_wall at that point and do the change of variable yourself.
You can also divide the yplus you have by the local cell wall distance and you obtain a quantity that can just be multiplied by any distance and return your new y+ value in all the locations
hamed1983 likes this.
sbaffini is offline   Reply With Quote
Old   May 11, 2022, 06:30
Hamed
Dear Sbaffini,
Thanks for your prompt reply. However, I was wondering if there is any built-in feature in Starccm to do that?
Actually, I don't know how to implement this part of your message
"Now, if you want to have a nice plot of the u+ vs y+ for a given profile extracted along a normal to the wall in a given point, you need to extract the tau_wall at that point and do the change of variable yourself."
regards
Old   May 11, 2022, 07:09
sbaffini's Avatar
Paolo Lampitella
Well, the profile part is typically simple and common to several software, yet I have zero knowledge of starccm.
I don't think there is any code automating this. In order to do this manually you need to take care of two issues:
1) When you pick up a general point on a surface, the relevant velocity to extract along the normal n is the one parallel to the wall: u - (u*n)n
2) The tau_wall has to be extracted at the intersection between the line you extract and the wall
Old   May 11, 2022, 09:04
Lucky
Star gives you tau at the wall and y+ and u* at the wall adjacent cells. Star does give you the distance to the nearest wall for a cell in the interior volume but it does not give you y+,u+, nor u* there. There isn't a general framework for how to compute y+ and u+ for an arbitrarily complex 3D flow, this part you have to do yourself.
Old   May 12, 2022, 14:58
Paul Hancock
Paulh is on a distinguished road
If you have access the to Siemens Support Center site, you might want to take a look at this article:
https://support.sw.siemens.com/en-US...00037693_EN_US
If the link doesn't work, you can search for an article titled:
How to plot y+ and u+ boundary layer profiles normal to a wall
Paulh is offline   Reply With Quote
buffer zone, star ccm, y plus ranges, y plus selection
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 09:26
[snappyHexMesh] layer not added Rasmusiwersen OpenFOAM Meshing & Mesh Conversion 1 January 2, 2020 10:43
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 06:53
Prismatic boundary layer KateEisenhower enGrid 5 September 15, 2015 08:48
errors Fahad Main CFD Forum 0 March 23, 2004 14:20
