why some solvers use non-dimentionalized form of navier-stokes equations? |
Sayan Bhattacharjee
Rep Power: 5 ![]() |
NASA's CFL3D and FUN3D solvers seems to non-dimensionalize the governing equations.
I could not find or understand the reason behind such a decision. Can anyone please explain why they did it, and was there any benefit or side-effect from doing it? |
Lucky
Rep Power: 57 ![]() ![]() ![]() |
1) Governing equations are never truly non-dimensionalized at the linear solver level. You have a coefficient matrix that needs solving and that's it. What's different is the user-interface: the user must provide a mesh (dimensional or non-dimensional) and then make sure that all the boundary conditions and settings (all user inputs) are in units consistent with the mesh provided.
2) NASA and many other US/English-companies engineer using English units. We're talking about inches-feet-miles, pounds, slugs, Farenheit, inches of water, psi, and so on. It is deeply ingrained in these work cultures to have conversion factors everywhere in all their equations and for them, it's really no big deal whether a particular software is dimensional or non-dimensional because they always go through the same process of converting units in and out of English units anyway. It's not any better one way or another. |
Filippo Maria Denaro
Rep Power: 64 ![]() ![]() ![]() |
There is a fundamental theoretical reason to work in non-dimensional form.
If you choose correctly the characteristic scales of the problem you have that the variables will be O(1). This way is quite practical to check for correct results. |
#4 | |
Sayan Bhattacharjee
Thanks for your answer. English isn't my first language so I couldn't understand this part. Do you mean that the solution values come out in range [0.0, 1.0] , (like Cl and Cd for lift and drag), so it becomes easy for us to check if our results are correct without too much hassle? |
#5 | |
Well, it could be also 3, 5.1, 6 ... the term O(1) means that. The key is to have the correct knowledge of the problem and to choice the proper reference values. |
Display Modes | |
Question about governing equations of standard solvers | Jerry L.D. Cheng | OpenFOAM | 0 | March 8, 2015 07:22 |
Convective term in Linearized Navier Stokes Equations | And901 | OpenFOAM Programming & Development | 0 | October 22, 2014 11:00 |
Navier stokes compresible viscid flow fea, somebody can help? | Jose Choy | Main CFD Forum | 3 | October 24, 2003 02:28 |
help: I am trying to solve Navier Stokes compressible and viscid flow | Jose Choy | Main CFD Forum | 2 | May 18, 2000 05:45 |
Computational complexity of Navier Stokes equations | Marco Ellero | Main CFD Forum | 5 | May 5, 1999 21:07 |
