when should I turn on Discrete Random walk model ?
Like Tree1Likes
  • 1 Post By alainislas
Old   June 11, 2022, 00:59
Default when should I turn on Discrete Random walk model ?
Dai Li
daily_7 is on a distinguished road
I use DPM to simulate coal particles flow pattern in coal pulverizer. The volume fraction of solid phase is smaller than 8%. The diameters of particles are 0.01-0.1mm. The gas phase use RANS model. Should I consider the effect of turbulence? When can I use the Discrete random walk model?
daily_7 is offline   Reply With Quote
Old   June 14, 2022, 08:46
echo
2424464575 is on a distinguished road
hello,you use the UDF?
2424464575 is offline   Reply With Quote
Old   June 14, 2022, 10:34
Dai Li
Sorry, no.
Old   June 24, 2022, 18:39
alainislas's Avatar
Alain Islas
alainislas is on a distinguished road
DRW should be enabled with RANS models only. Since in RANS you don't solve for the instantaneous gas velocities, the discrete particles trajectories should include some sort of turbulence. These velocity fluctuations are sampled from a gaussian distribution with standard deviation assuming isotropic turbulence. The model performs quite well in the free-stream region but should be used with caution in the near-wall, especially small particles are prone to exhibit weird behavior
You can read the original work from the 80's by Gosman and Ioannides, from Imperial College
joshwilliams likes this.
alainislas is offline   Reply With Quote
Dense discrete phase model Theerawat FLUENT 6 April 21, 2016 17:13
Spray Modelling within the Discrete Phase model Jufri FLUENT 2 March 18, 2015 05:17
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Model with L turn c0384 Siemens 0 July 4, 2008 21:33
