Air flows from lower total pressure to higher total pressure |
July 2, 2022, 23:50 |
Kevin
Rep Power: 3 |
I'm simulating a natural exhaust hood. The air near the hot surface has a lower density so it will go up due to buoyancy. I have checked the outlet flow rate and it has an outlet volumetric flow rate of 1000 m3/hr without any reverse flow. The problem is that the total pressure at the outlet is much higher than the duct entry. So, how the air can exit the outlet while the fluid flows from higher total pressure (TP) to lower pressure? You can see the pressure contours below: Thank you! |
July 3, 2022, 00:11 |
Lucky
Rep Power: 65 |
You have an external force, gravity aka your buoyancy force!
Not sure if it's relevant but you should also be careful what is the definition of pressure, static pressure, and total pressure when working with gravity driven flows because it may or mot not include the hydrostatic component. |
July 3, 2022, 00:29 |
#3 | |
Kevin
Rep Power: 3 |
You mean I have to define a function as: FULL_PRESSURE= Total Pressure -rho*g*y? I'm confused. |
July 3, 2022, 01:06 |
Lucky
Rep Power: 65 |
There is a lot going on in this picture that is not easily explained away by a few words especially when you are confused what is pressure.
To make it even more confusing, there's also heat transfer and you're putting energy into the flow. |
buoyancy driven flow, pressure and velocity |
chtMultiRegionFoam speed up | qwertz | OpenFOAM Running, Solving & CFD | 8 | September 18, 2021 06:16 |
Getting divergence while increasing the back pressure at pressure outlet | greenfields15 | FLUENT | 0 | March 18, 2018 23:39 |
total pressure and pressure drop | omaralyahia | CFX | 5 | July 14, 2015 08:13 |
Dynamic pressure from the total pressure specified | saisanthoshm88 | CFX | 1 | August 9, 2012 06:13 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
