August 7, 2022, 03:39 |
A water tank subjected to frame motion
Abdullah
I am simulating a water tank subjected to discontinous velocity. At the point of discontinuity a pressure surge is seen in "area weighted average Max pressure" curve then it stablizes. I just want to know that is this term corrwcr or not. Example: Velocity changes at 10secs (linear Velocity profile is used) At 9.995 pressure is 5000Pa At 10.005 pressure is 5500 Pa At 10 pressure is 120 KPa |
August 7, 2022, 05:03 |
Which CFD software do you use?
August 7, 2022, 05:21 |
Abdullah
I am using ansys fluent
August 8, 2022, 10:23 |
Rep Power: 18 |
Are you familiar with the impulse-momentum form of Newton's 2nd law? You have a momentum change when the velocity changes - if the change is very rapid then you can easily generate an impulsive type force. A better way to think of it is that you would need to apply a large impulse to generate the observed or desired change in velocity. But fundamentally you have the impulse I = (Mass)x(Velocity2 - Velocity1). The impulse is the integral of the applied force over the time applied, so for your case it could be approximated as 0.5*(Timestep)*(120000 Pa - 5000 Pa)*(Area of application). I don't know your setup, so that's as far as I can go. But you should be able to work out the rest.
frame motion, pressure and velocity, sloshing tank, surge tank |
water in tank with vortex baffles | Shamoon Jamshed | FLUENT | 3 | February 9, 2022 08:10 |
Keeping inlet mass flux the same as outlet mass flux in an water tank | vaibhav402 | Main CFD Forum | 0 | October 13, 2015 03:02 |
Setting Up a case on building an empty tank with water going into the tank | Nori4U | OpenFOAM Programming & Development | 1 | May 8, 2015 02:10 |
Water tank baffles - modeling the flow with tank half full | A_Prakash | CFX | 11 | January 1, 2015 10:43 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
