August 22, 2022, 10:13 |
Need help to validate my simulation result
Tintunoo
problem description -
-free fall rocket like object drop from 500 meters. -desired results are forces and moment coefficient for rigid body simulation. -free stream velocity 60 m/s. -angle of attack 5 deg. simulation setup - -box far field domain 10 times body length for 3D simulation. -inlet, top and bottom patches are velocity inlet type. -symmetry sides. -pressure outlet. -turbulent Model is kOmegaSST. -simpleFoam solver. Mesh -snappyHexMesh with 3 boundary layers of thickness 0.7 -total number of cell 1 Million. HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (59.771681 5.02293445 0); boundaryField { airdrop { type noSlip; } inlet { type fixedValue; value uniform (59.771681 5.02293445 0); } outlet { type zeroGradient; } sides { type symmetry; } } // ************************************************************************* // HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "1"; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { airdrop { type zeroGradient; } inlet { type zeroGradient; } outlet { type fixedValue; value uniform 0; } sides { type symmetry; } } // ************************************************************************* // HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "1"; object omega; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 -1 0 0 0 0]; internalField uniform 864200; boundaryField { airdrop { type omegaWallFunction; value uniform 1; } inlet { type turbulentMixingLengthDissipationRateInlet; mixingLength 0.014; value uniform 0.014; } outlet { type zeroGradient; } sides { type symmetry; } } // ************************************************************************* // HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "1"; object nut; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { airdrop { type nutkWallFunction; value uniform 0; } inlet { type calculated; value uniform 0.01934; } outlet { type calculated; value uniform 0; } sides { type symmetry; } } // ************************************************************************* // HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "1"; object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.1; boundaryField { airdrop { type kqRWallFunction; value uniform 1; } inlet { type turbulentIntensityKineticEnergyInlet; intensity 0.01; value uniform 0.01; } outlet { type zeroGradient; } sides { type symmetry; } } // ************************************************************************* // HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object transportProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // transportModel Newtonian; nu 1.5e-05; // ************************************************************************* // HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object turbulenceProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // simulationType RAS; RAS { RASModel kOmegaSST; turbulence on; printCoeffs on; } // ************************************************************************* // HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application simpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 15000; deltaT 1; writeControl timeStep; writeInterval 10; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; functions { forceCoeffs1 { type forceCoeffs; libs ("libforces.so"); writeControl writeTime; writeFields true; patches (fuckingbomb); p p; U U; rho rhoInf; // Indicates incompressible log true; rhoInf 1; // Required when rho = rhoInf liftDir (0 1 0); dragDir (1 0 0); CofR (0 0 0); // Axle midpoint on ground pitchAxis (0 0 1); magUInf 60; lRef 2.41; // Wheelbase length Aref 4.56; // Estimated } yPlus1 { // Mandatory entries (unmodifiable) type yPlus; libs (fieldFunctionObjects); // Optional (inherited) entries writePrecision 8; writeToFile true; useUserTime true; region region0; enabled true; log true; timeStart 0; timeEnd 1000; executeControl timeStep; executeInterval 1; writeControl timeStep; writeInterval 10; } } // ************************************************************************* // HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; grad(p) Gauss linear; grad(U) Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss linearUpwind grad(U); div(phi,k) bounded Gauss upwind; div(phi,omega) bounded Gauss upwind; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } // ************************************************************************* // HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-7; relTol 0.1; smoother GaussSeidel; } Phi { $p; } U { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.1; nSweeps 1; } k { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.1; nSweeps 1; } omega { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.1; nSweeps 1; } } SIMPLE { nNonOrthogonalCorrectors 3; } potentialFlow { nNonOrthogonalCorrectors 10; } relaxationFactors { fields { p 0.3; } equations { "(U|k|omega)" 0.7; "(U|k|omega)Final" 1.0; } } cache { grad(U); } // ************************************************************************* // only Ux and omega resudual went below 1e-5. other residual doesn't goes below 1e-3. -yplus value are y+ : min = 81.6281, max = 13216.4, average = 1185.81 HTML Code:
Time = 639 smoothSolver: Solving for Ux, Initial residual = 9.52204e-05, Final residual = 6.89428e-06, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.000402492, Final residual = 2.90737e-05, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.00496712, Final residual = 0.000361654, No Iterations 3 GAMG: Solving for p, Initial residual = 0.00923487, Final residual = 0.000304668, No Iterations 2 GAMG: Solving for p, Initial residual = 0.0010415, Final residual = 5.96551e-05, No Iterations 2 GAMG: Solving for p, Initial residual = 0.000171178, Final residual = 1.68851e-05, No Iterations 2 GAMG: Solving for p, Initial residual = 4.20648e-05, Final residual = 2.52407e-06, No Iterations 3 time step continuity errors : sum local = 6.28704e-08, global = 1.01751e-09, cumulative = 0.00119196 smoothSolver: Solving for omega, Initial residual = 2.4579e-05, Final residual = 1.75449e-06, No Iterations 3 smoothSolver: Solving for k, Initial residual = 0.000100212, Final residual = 7.69947e-06, No Iterations 3 ExecutionTime = 3194.77 s ClockTime = 3379 s forceCoeffs forceCoeffs1 execute: Coefficients Cd : 0.267388 (pressure: 0.251521 viscous: 0.0158662) Cs : -0.0281329 (pressure: -0.0283496 viscous: 0.000216715) Cl : 0.337512 (pressure: 0.336583 viscous: 0.000929208) CmRoll : 0.206183 (pressure: 0.205689 viscous: 0.000494358) CmPitch : 0.669585 (pressure: 0.657872 viscous: 0.011713) CmYaw : -0.125541 (pressure: -0.116004 viscous: -0.00953733) Cd(f) : 0.339877 Cd(r) : -0.0724894 Cs(f) : -0.139607 Cs(r) : 0.111475 Cl(f) : 0.838341 Cl(r) : -0.500829 -is my result acceptable and how can i improve to have convergance. Thank in advances. |
convergence issue, free fall analysis, incompressible fluid, simple algorithm |
Unusual oscillation in my MHD simulation result | nothingts | Main CFD Forum | 0 | June 6, 2019 08:05 |
Comparison the airfoil 0012 experimental result and simulation result | harrislcy | FLUENT | 30 | August 29, 2013 11:27 |
How to separate two waves in my simulation result? | hadesmajesty | Main CFD Forum | 0 | October 13, 2009 01:42 |
Single phase result file for multiphase simulation | Kushagra | CFX | 2 | July 8, 2008 22:14 |
transient simulation result file (.trn) ? | amine | CFX | 3 | June 14, 2008 06:01 |
