meaning of this formula
Like Tree4Likes
  • 1 Post By FMDenaro
  • 1 Post By agd
  • 1 Post By LuckyTran
  • 1 Post By mahinseo
Old   October 4, 2022, 04:36
Question meaning of this formula
FluidKo is on a distinguished road
Hello everybody~!
I have a question about turbulence.
I'm taking turbulence lecture but actually I have not taken Engineering mathematics 2 before.
So I have no idea of many theories those are built by Fourier.
But I should take this lecture.
https://www.youtube.com/watch?v=izdE...X2o4TX&index=6
I don't know meaning of this formula.
\psi (x, y, t)=\phi (y)e^{i\alpha (x-ct)}
I've read wiki about Orr–Sommerfeld equation briefly and I've seen below equation.
u'\propto e^{i\alpha (x-ct)}.
I think this is equation that describes disturbance but I have no idea of meaning, especially for exponential function.
Can you let me know meaning of this formula?
Thank you!
FluidKo is offline   Reply With Quote
Old   October 4, 2022, 10:21
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by FluidKo View Post
Hello everybody~!
Thank you!
I don't know the notes where you read this formula but:
1) if psi is a real function, in the RHS you must have a real function. Therefore phi should be complex but I don't understand why depends on y.
2) The argument (x-ct) stands for a linear wave solution with constant velocity c. That is the function simply shifts at speed c.
FluidKo likes this.
FMDenaro is offline   Reply With Quote
Old   October 4, 2022, 15:52
agd
agd is on a distinguished road
The function psi is a complex waveform, with the function phi being the real magnitude and the complex part representing the phase. The dependence on y for phi is typically representative of the behavior expected in flat plate boundary layers, with y being the coordinate normal to the plate. At least that's what I remember from the Orr-Sommerfeld derivations I worked through a long time ago.
FluidKo likes this.
agd is offline   Reply With Quote
Old   October 4, 2022, 16:43
Lucky
\psi (x, y, t)=\phi (y)e^{i\alpha (x-ct)}[/QUOTE]
means you have a parallel flow
means your disturbance u' is a wave
Neither of these are really statements but rather assumptions implicit to the analysis. You are looking for wavelike solutions of parallel flows, not all possible solutions of any arbitrary flow.
FluidKo likes this.
Old   October 5, 2022, 23:14
Banned
mahinseo is on a distinguished road
am writing a thesis on open channel axial water turbine simulation.
As for the setup, i am using transient, VOF (air and water) open channel, k-e RNG model, standard wall fn.
I have set up everything else normally such as the free surface level and boundary conditions such as pressure inlet, pressure outlet, and another pressure outlet at the top surface.
For geometry,
I have 2 domains, one stationary and one rotating domain for the turbine.
Both are set with numerical beach, with the stationary domain using frame motion and the rotating domain using mesh motion with the setup seen in the picture
FluidKo likes this.
mahinseo is offline   Reply With Quote
Old   October 8, 2022, 02:57
Thumbs up
Aha. That is just describing fluctuation into waveform.
Thank you guys.
Thermal diffusion coefficient empirical formula Chris S FLUENT 6 September 11, 2018 18:49
Help about meaning and formula of CFD symbols nguyenpt Main CFD Forum 0 February 21, 2016 23:32
Any formula for approximating the boundary layer thickness around a cylinder? bestniaz Main CFD Forum 0 October 24, 2015 02:00
formula implementation sanjar OpenFOAM Running, Solving & CFD 3 September 12, 2013 12:35
Benetton Formula 1 CD adapco Group Marketing Siemens 13 February 7, 2002 09:33
