Anisotropic Taylor microscale
Like Tree1Likes
  • 1 Post By Lalilulelo
Old   January 3, 2023, 19:00
Default Anisotropic Taylor microscale
rdemyan is on a distinguished road
The Taylor microscale in isotropic turbulence is given by:
\lambda = \sqrt{ 15 \frac{\nu \ v'^2}{\epsilon} }
where v' is the root mean square of the velocity fluctuations. In general, for velocity fluctuations in three dimensions:
v' = \frac{1}{\sqrt{3}}\sqrt{{v'_1}^2+{v'_2}^2+{v'_3}^2}
So plugging this expression into the Taylor microscale equation yields:
\lambda = \sqrt{ 5 \frac{\nu}{\epsilon} }\sqrt{{v'_1}^2+{v'_2}^2+{v'_3}^2}
Now for isotropic turbulence
v'_1=v'_2=v'_3
So for isotropic turbulence, equation 3 (third equation in this text) yields:
\lambda = \sqrt{ 5 \frac{\nu}{\epsilon} }\sqrt{{3v'_1}^2} = \sqrt{ 15 \frac{\nu \ {v'_1}^2}{\epsilon} }
which is expected and is basically the first equation in this post.
My question is: can I use equation 3 to calculate the Taylor microscale for anisotropic turbulence. For example if the injection of energy is highly anisotropic where v'_2 = v'_3=0
\lambda_A = \sqrt{ 5 \frac{\nu}{\epsilon} }\sqrt{{v'_1}^2}=\sqrt{ 5 \frac{\nu \ {v'_1}^2}{\epsilon} }
where \lambda_A is the anisotropic Taylor microscale. Does this seem correct? Also, does anyone know of a reference where this derivation was already done?
rdemyan is offline   Reply With Quote
Old   January 25, 2023, 10:06
Alan
Lalilulelo is on a distinguished road
I gave you an answer on SE.
arjun likes this.
Lalilulelo is offline   Reply With Quote
How to implant anisotropic conductivity UDF inside fluent's PEMFC module brucelqs Fluent UDF and Scheme Programming 7 September 7, 2022 03:29
How to implant anisotropic electrical conductivity UDF inside fluent's PEMFC module brucelqs Fluent UDF and Scheme Programming 0 June 24, 2022 04:41
UDF - Anisotropic Conductivity sasanghomi FLUENT 0 August 25, 2020 10:30
Question about anisotropic thermal conductivity Szweyk STAR-CCM+ 2 June 30, 2016 09:26
anisotropic porosity in CFX Chander CFX 19 June 17, 2014 05:51
