January 17, 2023, 17:40 |
Heating Air/Liquid Cavity 2d-Transient
Tarık Yaman
Rep Power: 4 |
Greetings, I am interested in gas heating in closed and constant volume region. But I have some thoughts, I want to share them with you and get advice.
Its volume is constant, if I heat any gas (example: air), its density does not change. Therefore, my material is of constant density. When a constant volume of gas is heated, its pressure will increase. From the ideal gas behavior I get the following relation: P_1/T_1 = P_2/T_2 At the same time, an increase in viscosity will occur due to the increase in pressure. **I should use C_v instead of C_p because in my analysis the volume is constant, not the pressure. I want to adjust these values according to temperature and pressure in Fluent, I think I need to work hard to find these values. Since pressure increases proportionally with temperature, I actually have to write them all as a function of temperature. I have to open the thermodynamics book. Or am I thinking of too many details? Is there a method that will lead us to similar results with a little error? About this subject; Do you suggest any adjustments in material settings, solution methods, controls? Thank you in advance for your help and feedback. |
cavity problem, natural convection, transient |
Boundary conditions for supersonic flow over a cavity. | harji95 | FLUENT | 0 | July 5, 2020 11:07 |
Transient simulations: how to tell its converged (I've read the FAQ & user guides!) | JuPa | CFX | 12 | March 27, 2020 17:24 |
Input File for transient cavitating flow | Badi | CFX | 13 | July 1, 2013 09:28 |
Transient flow in fluent | linyx | FLUENT | 15 | April 24, 2013 09:54 |
difference between false and true transient | mahesh prakash | Main CFD Forum | 1 | January 21, 1999 13:45 |
